  #1
Old September 1st, 2008, 07:56 AM
apn3a apn3a is offline
Default Vibration and power loss at high rpm 1996 30 Yamaha 2-stroke 3 cylinders
hello i recently started having an issue with my outboard motor. It operates fine for a good amount of time and all of a sudden in high rpms (3/4 to 4/4) it starts vibrating and there is a power loss. It runs fine at 1/4 and 1/2 with no vibration and power loss. In the past, when the vibration and power loss was happening, I knew that the oil tank was low so i would just fill it up and everything would be fine. Now the oil tank is full but it does it anyway. Does anyone have any ideas as of what could be causing this? It does not happen as soon as i start the motor. It happens after about 30min when i go on high rpms.
thanks
  #2
Old September 1st, 2008, 09:18 AM
mthieme's Avatar
mthieme mthieme is offline
Default Re: Vibration and power loss at high rpm 1996 30 Yamaha 2-stroke 3 cylinders
Does it vibrate in neutral?
If so you can rule out the drive train and it is something in the powerhead.
Are their any noises that you can discern?
The only time I have experienced a vibration was from a bent prop. I assume you've checked this (?).
__________________
Nothing is so broken that Government can't make it worse.
  #3
Old September 1st, 2008, 11:46 AM
no it does not vibrate at all at neutral. I already checked the prop, i was sure that that was not the case since it starts vibrating after 15-30 min. There are no other noticeable noises whatsoever. When i reduce the speed, it stops vibrating. I run it for about 5 min at low speed and then i go to high rpm again. But after about 5 min it starts to vibrate again, i have power loss, and i have to cut my speed to 1/2. Any other suggestions? Could it be the oil pump? like it does not provide oil to the engine sufficiently in high rpm?
  #4
Old September 2nd, 2008, 12:55 AM
Yamajoe's Avatar
Yamajoe Yamajoe is offline
You need to check your oil sensor and temp sensor. The motor is shutting down to safe mode to protect itself; the reasons this occurs is if you are running low on oil, the motor is overheating and or it is reviing beyond the recommended WOT rpm.
High temp problems are caused by blocked or restricted water intake (lower unit), water pump, thermostat and heavily corroded or build up in the water passages.
  #5
Old September 6th, 2008, 02:58 PM
after checking all the sensors it seems that when i disconnect the temperature sensor there is no vibration whatsoever. So that means that either the temp sensor is bad or there is an overheating problem. But i doubt there is overheating since the water coming out of the engine seems to be under high pressure. If there was a problem either with the pump or with the water intake, the water that comes out of the engine should have lower pressure. rite..?
  #6
Old September 6th, 2008, 07:28 PM
Yamajoe's Avatar
If you cannot hold the palm of hand on the side or top (be careful of moving parts) of motor for more than 30secs, then you should check and replace the water pump and thermostat; also. The water pressure coming from the pee hole is a fair indication of the state of the pump, but i would not rely on the pressure or lack there of; if the water is hot too touch, then you have a problem with your cooling system. Someone here can give you test procedure for the sensor, but my guess is you need to check and replace the pump and thermostat; don't run the motor without the sensor until you have verified the source of the problem and it is resolved.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Suzuki DF140 Power Loss at High RPM tkendall Yamaha & Suzuki Outboards 12 January 30th, 2008 04:15 PM
Power drops after about 30 seconds at high rpm imported_Jay Johnson & Evinrude Outboards 2 July 3rd, 2006 11:44 AM
2000 Yamaha 90hp 2 stroke low rpm power loss bkirb Yamaha & Suzuki Outboards 0 May 28th, 2005 07:51 AM
Power loss at high rpm Mercury 15hp 1990 Dutchdude Mercury & Mariner Outboards 1 August 19th, 2004 10:39 PM
loss of power at high rpm sluggonn Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 26th, 2003 02:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
