Hello all--kinda long post, but I'm stumped. I picked up a Johnson J10RENA of off Craigslist for $200. It had been sitting for several years, but looked good.
So far, here's what I've done with the motor:
-Carb cleaning & rebuild with oem kit. The carb was filthy, but I've managed to get it cleaned up and now have all the right gaskets in all the right spots. (took me a few tries to get it right) All orifices and jets are open and clean.
-New water pump impeller
-Changed lower unit lube (old stuff was dark, but no water)
-New thermostat kit (a little bit of mineral buildup in the housing, but not bad)
-New head gasket (after seeing the mineral buildup in the 'stat, I wanted to see what the cooling jackets were like. They were clean and the cylinders/pistons were just fine. A little carbon on the piston crowns that I cleaned)
-Rebuilt starter rewind spring assembly (what a pain) and new starter rope.
-Dismantled, cleaned up, and repaired twist throttle and cable assembly.
-Very strong, even compression
-Good spark (pull the plugs, ground them, pull the rope, I get bright blue sparks with sharp "snaps" when each one fires)
OK . . . here's the rub . . . At best, I can get this thing to fire at 1/2 throttle or more, it may run for ~15 to 20 seconds, slobber down, and die. Lots of heavy smoke. When it's running (?), it's VERY rich and unresponsive. At first, I suspected that the plastic housing that holds the main jet wasn't sealing on it's top & bottom, so I verified that the gaskets are being compressed properly. (items 2, 6, 8 on exploded diagram found here http://shop2.evinrude.com/ext/index.aspx?s1=37ab03687d3a363c094c11b33e628b2e)
At this point, I'm stumped. I will tear into the carb (again) and see if I've missed something. Does anyone have any thoughts? (reed valves, ignition, ???) Everything I've ever known says this motor should run like a scalded ape.
Sorry for the long post.
Terry
Terry
