Re: Evinrude 9.9 HP , No Spark
The "Outboard Wont Start" thread by JB in the FAQ will be of interest to you.
In regards to your NO SPARK scenario, go over the following. Extracted from the CDI Troubleshooting Guide.
1. Disconnect the black/yellow stop wire and retest. If the engine's ignition has spark, the stop circuit has a fault-check the key switch, harness and shift switch.
2. Check the stator and trigger resistance and DVA output as given below:
Wire Color: Check to Wire Color: Resistance: DVA Reading
Brown wire: Brown/Yellow wire: 450-550: 150V or more Connected
Black/White wire: White/Black wire: 15-42: 0.6V or more Connected
Some engines use the following wiring on the trigger:
White wire: Blue wire: 15-42: 0.6V or more Connected
White wire: Green wire: 15-42: 0.6V or more Connected
3. Check the cranking RPM. A cranking speed of less than 250-RPM will not allow the system to spark properly.
4. Check the DVA output on the orange wires from the power pack while connected to the ignition coils. You should have a reading of at least 150V or more. If the readings are low, disconnect the orange wires from the ignition coils and reconnect them to a load resistor. Retest. If the reading is now good, the ignition coil is likely bad. A continued low reading indicates a bad power pack.
