  #1
Old August 30th, 2008, 07:54 PM
manuelmercury manuelmercury is offline
Default mercury 1976 1750 v6 2 stroke outboard melted piston
bought the boat from a non profit organization with no info other than it had sat for the last four years.got it home and would not kick over. after some troubleshooting replaced the ignition switch and started up after awhile. replaced water pump(impellar was toasted as was upper part of water pump). started her back up and sounded rough.took her to the lake and had hard time starting her up when she finaly started i put it in gear and it died out this went on a few times then finaly got it to move. went about 30 yards and she died and would not start back up.got her home put muffs back on and she started. did a compression check and all had 120 except lower right (5?) which was 5psi. removed the head and piston was melted inward. rings looked to be intac. cylinder has no scoring or scratches although cross hatchings are not visible in that cylinder. also that cylinder was dry. no fuel/oil going into it.my next move is to remove carbs and clean them and put new gaskets on and replace piston in #5 and all piston rings. is there anything else that i missed or should be looking into or am i on the right track? by the way ive never worked on a boat before but i do have the seloc manual and have worked on cars.also will the carb problem and a bad piston cause it not to run in the water?
  #2
Old August 31st, 2008, 01:01 AM
emckelvy emckelvy is offline
Default Re: mercury 1976 1175 v6 2 stroke outboard melted piston
A "dead hole" will definitely make it run poorly in the water!!
Most likely #5 had been running lean for quite a while and probably burnt up from detonation.
What I'd recommend is servicing ALL the carbs while the motor is down for repairs. Then you know this isn't going to happen again. Also check all the fuel lines for rot/restrictions. Rebuild the fuel pump(s), you can get a diaphragm/gasket kit cheap enough.
There are a few problem areas which would be good to address while it's apart; if you're replacing rings in all cylinders, you'll be replacing both head gaskets. That's a Good Thing as it's not uncommon to see head gasket problems crop up on older motors. Even if you don't open the motor up that far, be sure to do both heads.
Take the heads to an automotive machine shop and have them surfaced/trued up. You can even do this yourself by using sandpaper on a metal surfacing plate or piece of glass.
Another problem area lies with the exhaust manifold. The gaskets dry up and then they leak water into the engine. Not good for running either! New gaskets will ensure you don't have any problems with the motor down the road. Inspect the inner exhaust baffle for cracks, perforations, and warpage. This sealing area is (besides the heads) just about the most critical.
Be sure you replace the wristpin and conn rod big-end roller bearings when you renew that piston. Note you may be able to find a very servicable piston/rod assy on eBay, it's worth a look anyway.
When renewing the dead cylinder, if the conn rod has body-fit bolts with nuts, you can re-use the rod bolts. Degrease and put a drop of Red Loctite on the nutted area of the threads.
If the conn rod bolts thread directly into the rod, without nuts, you MUST renew the bolts as they are "stretch" or Torque-to-Yield bolts and cannot be reused. If you do they are virtually guaranteed to break.
Be sure to torque the conn rod bolts, head bolts, and exhaust manifold bolts to specs. You'll need to pick up a manual to help with this. These torques are extremely critical and can cause you to lose an engine if not done correctly.
When you're in there, check the upper and lower crank bearings for roughness, inspect the crankshaft and rods for pitting/wear/etc. Renew the upper and lower crank seals.
You'll also want to time/synchronize the motor to specs, this'll ensure you don't destroy it from detonation caused by too much spark advance.
One last thought, I can't recall if the 175 had chrome bores, but if it does, don't use any kind of hone or 'glaze-buster' on it.
If they're just steel liners, it's OK to use one of the "dingleball" type of deglazers to 'rough up' the bores so they'll seat-in new piston rings. Only run the glaze-buster enough to get a good cross-hatch, and no more.
The V6 actually isn't that bad of a motor to work on, it's just a bit on the heavy side. Don't try lifting it off the motor by yourself, get a strong friend, an engine hoist, or eat a bunch of Wheaties before you start. I did it in my younger days but no more, that's fer sur!
Oh, and this site is a great place to look up parts/diagrams for your motor:
http://www.mercruiserparts.com/Selec...asp?class_id=2
HTH & Happy Wrenching...........ed
  #3
Old August 31st, 2008, 02:41 AM
ed thanks alot for the insight. i will definetly look through the whole power head for any other wear and tear.i planned on cleaning up all carbs.and yes the port side gaskets are leaking on the head and thermostat so those will definatly get replaced. and no these cylinders are not chromed lined.well id appriciate all other comments and help. i will keep all up to date as i progress!
  #4
Old August 31st, 2008, 06:11 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
My first tip would be to lose the solec and buy a Merc genuine manual... You're need it for a re-build.
Chris.......
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #5
Old September 1st, 2008, 11:17 PM
took the carbs off today, they looked pretty clean.all holes seemed to be clear not gummed up or anything. soaking them in carb cleaner anyway.float looked discolored a little but looked pretty good. gonna replace anyways.ill keep you all up to date.
  #6
Old March 28th, 2009, 10:54 PM
Default Re: mercury 1976 1750 v6 2 stroke outboard melted piston
after 7 months im getting back into fixing the boat.today i pulled the power head off i noticed the lower end cap had alot of black soot on it, is this normal?
  #7
Old March 29th, 2009, 12:36 PM
anybody?anything?
  #8
Old March 30th, 2009, 02:22 PM
opened her up and found that when the piston melted the skirt shattered and pushed two holes through the block and cover.
  #9
Old April 2nd, 2009, 10:23 PM
decided to weld it with alumi-pro welding/brazing rods.i have nothing to loose. i ordered $250 worth of parts when i took off the cylinder head and saw that the piston melted but cylnder and evrything else looked good.wasnt until i took the engine apart more that i saw the hole and crack. tried a trial test with the alumi-pro welding two pieces of aluminum bar together and hammered the heck out of it while in a vise and couldnt break it apart until i used a small sledge hammer.will post before and after pictures and let everyone know how it goes.place your bets. note one hole is at the bottom of piston cylinder next to rod hole/passage about the size of a nickle square in shape. one crack is in the crankcase cover horseshoe shape and another crack in the the bottom of another piston cylinder horseshoe shape as well.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Piston is Melted in #2 cyl on 85HP Reboot11133 Force & Chrysler Outboards 5 June 29th, 2008 10:25 PM
03 50 horse Mercury 4 stroke voltage regulator melted down mikerino Mercury & Mariner Outboards 6 June 28th, 2007 10:26 AM
melted or burned up piston? dragula65000 Johnson & Evinrude Outboards 20 January 3rd, 2006 09:59 AM
1150 Merc. Melted #1 piston WHY? Hook328 Mercury & Mariner Outboards 4 October 11th, 2004 01:28 PM
melted piston on 90hp Rude VRO shallowriverrunner Johnson & Evinrude Outboards 3 February 1st, 2003 02:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
