I am having an intermittent problem with the ignition. The boat starts good all the time from cold. But having run out with no problems on a few occasions on returning to harbor when shifting to Neutral the ignition has cut out and will not restart it appears there is no spark present. I have good voltage at the coil and 12 or 7 volts at the distributor depending where the blades are on the rotor. I can only think its the sensor or it could be something stupid like the rotor is not touching the top of the distributor. Any advice much appreciated.
