Need Help With A 1999 Xr6 150 With A New 200 Head On It. The Boat Boggs Down When Hotfoot Is Press All The Way Down. The Boat Sounds Like It Is Choking Out For About 100-150 Ft Then Will Take Off On. Runs Great On Top End And Idles Fine. Motor Has On 12 Hr On It And I Thought It Was The Double Oil Causing This. Not Sure What The Low Timing Or High Time Should Be? Or Is This Another Problem. Rebuilt Carbs, New Trigger, And New Power Pack.
Any Suggestions? Thanks Barry
