  #1
Old August 30th, 2008, 11:45 AM
neznaika neznaika is offline
Post 115hp Mariner Outboard ignition problem
Hi everyone! I have a 115hp Mariner O/M. I had it running this year once, but when I tried to start it again, i didn't get a spark on all cyl. I had a spark on 1-2-3-4 cyl. but after trying to figure out a problem (couldn't find anything) i had it on 2-3 cyl. only. What would be a problem? Thanks everyone!
  #2
Old August 30th, 2008, 11:55 AM
Laddies Laddies is offline
Default Re: 115hp Mariner Outboard ignition problem
I think that the way you describe it it's a 4 cyl but is it ADI or CDM ign, does it have a switch box or not?
  #3
Old August 30th, 2008, 12:05 PM
It is a CD ignition.
  #4
Old August 30th, 2008, 12:47 PM
Both systems are CD does yours have a switch box or not? We can't help if we don't know the tests are differant for the two.
  #5
Old August 30th, 2008, 12:55 PM
Yes it has switch boxes, and a year I believe is 1981, 6 cyl. inline.
  #6
Old August 30th, 2008, 01:04 PM
That really helps, was it so hard? Heres the test info.
  #7
Old August 30th, 2008, 01:42 PM
Thank you, I'll try that! but let me ask you this, i talked to my friend and he said it could be the cracked wires on the trigger. What's your opinion on this?
  #8
Old August 30th, 2008, 03:05 PM
It's a possible but each trigger winding effects only 2 cyls. there are 3 winding so it's unlikly that 3 would fail at once.
  #9
Old August 30th, 2008, 03:32 PM
Ok, here's what i found out after performing those tests:
stator- blue to ground 140v
stator- blue/white to ground 140v
stator- red to ground 15v
stator- red/white to ground 15v
trigger:
black to yellow sleeve
brown to white 1320 ohm
white to purple 1320 ohm
purple to brown 1320 ohm
I also swiched green wire on the coil from 3rd(working cyl.) to 4th(non-working cyl.) i had a spark on 4th cyl. That tells me that the coils are good. Then i did other way arround and i had no spark on 3rd cyl. Looks like to power from switchbox.
What do you think ?
  #10
Old August 30th, 2008, 03:42 PM
Disconnect the kill wire to the boxes then, try swaping the input wires from the stator to the boxes, red to red/white and blue to blue/white and see if that changes the spark from odd to even number cyls as one side of the stator powers 1 box and the other powers the other. If that don't work disconnect the bios wire between the boxes.
  #11
Old August 30th, 2008, 03:48 PM
Kill switch is the one connected to mercury switch?
  #12
Old August 30th, 2008, 04:25 PM
On your engine it'e orange I believe the newer engines it's black/yellow and it connect to the same place the mercury switch does. When you OHMed the trigger it checks fine the stator checks a little low but is working and some times a slow turning engine will cause low voltage. I am afraid the switch box bios has failed.
  #13
Old October 20th, 2008, 12:42 PM
Thank you very much for all of your info and help locating the problem. I bought new switchboxes and everything went to perfect order. Before I put them on, I had a weak spark, but now i see huge difference. Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner Ignition Problem leeworthy Mercury & Mariner Outboards 2 September 1st, 2007 10:05 AM
1995 115hp Starting problem - ignition switch? INHUNTER Mercury & Mariner Outboards 6 July 12th, 2007 09:38 PM
72 115hp ignition problem birdnbuck Mercury & Mariner Outboards 5 April 1st, 2007 08:04 PM
Mariner 115Hp idling problem LSH Mercury & Mariner Outboards 0 July 8th, 2005 07:35 AM
25hp Mariner ignition problem LaChonce Mercury & Mariner Outboards 0 August 17th, 2003 03:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
