Go Back   iboats Boating Forums > Repair and Maintenance > Electrics, Electronics and Trolling Motors
Reply
Thread Tools Search this Thread Display Modes
  #1
Old August 29th, 2008, 06:42 PM
sturdavj sturdavj is offline
Default Minn Kota bow mount ; How important is it for shaft to be plumb / motor level
I have an aluminum 16ft bay runner style boat with an upswept bow.
I have fabricated a bow plate and mounted a Minn Kota power drive starboard side of centerline. The motor is angled slightly upward; I could wedge the mounting bracket leaving a gap along the bracket but I would prefer not to if it’s not necessary.
My question is how important is it for the shaft to be plumb and the motor level?
I will be using this set up for low speed trolling.
  #2
Old August 29th, 2008, 07:11 PM
Silvertip Silvertip is offline
Default Re: Minn Kota bow mount ; How important is it for shaft to be plumb / motor level
Think about trimming your outboard or outdrive. Obviously the motor is most efficient when the prop is running straight. So shimming the mount is highly recommended. The shaft can be canted sideways and even if it is not perfectly plumb, performance will not suffer greatly. If the angle way off plumb then I would shim it.
  #3
Old August 29th, 2008, 10:25 PM
Thanks the quick response Silvertip.
I wasn’t sure if on the electrics the trim was as crucial. I am better off setting it up right from the get go, instead of spending time wonder if that was why the fish weren’t biting….
I’ll be taking my shims & tools to the water tomorrow.
  #4
Old August 29th, 2008, 10:49 PM
Splat's Avatar
Splat Splat is online now
Master Chief Petty Officer
I'm assuming you have the auto pilot version. The more level the motor shaft is the better it will track. If the motor is off kilter then the magnetic sensor will be slightly tilted and will cause some degree of variance.
On my boat using a Terrova with auto pilot there is a difference in front to back height of maybe 3/8 of and inch. Not a ton but it is noticeable if you look at it, especially with the shaft down. I have no problems with the autopilot working correctly.
Bill
  #5
Old August 30th, 2008, 09:04 PM
Wink Re: Minn Kota bow mount ; How important is it for shaft to be plumb / motor level
I got her mounted today, shaft is plumb. To provide some idea of how much the bow sweeps up, it required a 1 & 1/2 inch shim at the rear with the front of the mount sitting flush on the plate.
Splat; I am planning on upgrading to an auto pilot, I talked with the local Minn Kota service center and they seemed to think it could be done> Mine is a 1996 and I forgot to tell them the year. I guess I’ll find out
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Minn Kota 55 AT bow Mount ScottWilliams MMC Electrics, Electronics and Trolling Motors 0 April 22nd, 2007 02:04 PM
Minn Kota Maxxum 55 Bow-Mount Trolling Motor bakerlh Electrics, Electronics and Trolling Motors 4 February 1st, 2007 11:42 PM
Minn Kota Bow Mount BigTrouble Electrics, Electronics and Trolling Motors 4 May 12th, 2006 08:33 AM
Transom or Bow mount for Minn Kota Pelicano Electrics, Electronics and Trolling Motors 10 December 16th, 2005 04:57 PM
Help with a Minn Kota bow mount motor jsfinn Electrics, Electronics and Trolling Motors 7 April 6th, 2004 11:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
