  #1
Old August 29th, 2008, 06:32 PM
Janet Labrecque Janet Labrecque is offline
Question mercury 225 outboard power loss
Ihave a 1997 mercury 225EFI outboard. Recently had water pump trouble with the engine overheating badly. Replaced the water pump and Tstats and that problem is fixed only to have retarded timing at around 2500 RPM's. Any ideas???????
  #2
Old August 29th, 2008, 10:37 PM
CharlieB CharlieB is offline
Default Re: mercury 225 outboard power loss
Check/change fuel filters then check both primary and secondary fuel pumps for pressure and flow.
Secondary pump pressure must be checked again at speed and under load, pressure falling off indicates a problem with either the 2d pump OR the fuel level falling low in the accumulator which could be either a weak primary pump or restriction thru the filter or line or fittings.
This is IF it is even fuel related
You could have a stator beginning to weaken at temp.
Test spark stone cold then test again at full temp, say after a hard run and when the power is beginning to fade.
Need to determine whether it is ignition or fuel.
Since I sometimes think bass ackwards, read this post from end to beginning.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 225 Mariner Power Loss troy13 Mercury & Mariner Outboards 2 January 9th, 2009 02:43 AM
1983 115 mercury outboard loss of engine power please help!! rick wiles Mercury 4 October 7th, 2008 11:32 PM
85 Mercury Outboard-Loss of Power mercury85 Mercury & Mariner Outboards 1 July 8th, 2008 05:21 PM
225 Yamaha power loss Wiscbw Yamaha & Suzuki Outboards 6 September 17th, 2006 01:24 PM
Evinrude 225 power loss ProfPont Johnson & Evinrude Outboards 6 August 12th, 2004 07:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
