continuing from 7/24/08, 89 60hp evinrude replaced vro, now have cleaned & rebuilt carb's due to engine not idling below 1400 rpm's & stalls when put into gear. Also checked compression as advised 120 psi in all three, engine runs the same after carb o'hal but seem's like top two carbs are not getting enough fuel. I was checking spark while engine running & all 3 cyl have great spark but engine was not phased when i took plug wie off #1 (top cyl), put it back on & pulled #2 (MIDDLE) no change, engine still running the same. Pulled#3 engine died instanly! CCCCompression 120 psi all 3 cyl, strong spark all 3 cyl... seem's to be running off the bottom cylinder by itself, (crazy) what next?
