  #1
Old August 28th, 2008, 07:57 PM
boatmad1969 boatmad1969 is offline
Exclamation tell tale not working on mercury 115hp, urgent help needed!!
i was travelling to spain from portugal and on the way there my fuel gauge and trim gauge were not working, on the way back they were working but my tell tale wasnt, i have checked and it isnt blocked. any suggestions on how to make it work? are the two connected? and is it serious if it doesnt work?
many thanks
  #2
Old August 28th, 2008, 08:10 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: tell tale not working on mercury 115hp, urgent help needed!!
Squirt a hose up it.
  #3
Old August 28th, 2008, 08:30 PM
i took the cover off the engine, traced the pipes and disconnected them. water came out from a small pipe on the side of the engine (not the tell tale) but when i connect it all back together only a small dribble came out of the tell tale, the only pipe i couldnt check was clear was the pipe that goes down to the leg of the engine does this come from the impellor? and could it be blocked with sand?
thanks again
  #4
Old August 28th, 2008, 08:43 PM
Silvertip Silvertip is offline
You are experiencing a classic example of a failing water pump impeller. Since you have cleared any restrictions in the system, that is the next step for you. If the impeller has not been changed in the last couple of years it is due for this service. Failure of the impeller is very serious as it pumps cooling water through the engine. That's why the engine has a tell tale. It lets you know the pump is not functioning normally. When that pump fails the engine will overheat and seize, and a rebuild or new power head will be necessary.
  #5
Old August 29th, 2008, 09:49 PM
oh no that sounds like a lot of work, thank you so much! when it broke i had no idea were to start. your info has been taken on board and i will tell you how it goes THANKS AGAIN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Urgent help needed!!! ifishhard Mercury & Mariner Outboards 5 May 5th, 2008 06:33 PM
URGENT help needed 1978 9.8 merc jono_uk Mercury & Mariner Outboards 2 February 27th, 2008 04:44 PM
Mercury 150HP Outboard Tell Tale not working napicker Mercury & Mariner Outboards 4 September 11th, 2007 11:47 AM
1973 Merc 850, Urgent Help Needed scottrbishop Mercury & Mariner Outboards 6 June 6th, 2007 07:02 PM
URGENT ! Help needed on 1994 V6 gary91 Johnson & Evinrude Outboards 4 July 25th, 2004 05:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
