Re: Help! Is the prop suppose to spin when starting in neutral?
did you adjust the shift cable linkage as described above? It's one of two things, cable linkage, or the shift shaft in the lower unit.
Personally I would tackle the lower unit first, but that's just me. here's how:
Put controls in neutral, drop lower unit, turn shift shaft (small splined shaft that comes out with lower unit when you drop it) a turn, check that prop spins freely in both directions. if not, another click, then spin prop.. .might have to try clockwise as well as counter clockwise depending on which way you misaligned it. once the prop spins freely in both directions, give it a click clockwise and make sure the prop will ONLY spin forward. If this is the case, click it back into neutral and carefully re-assemble. Before tightening everything completely, test controls and prop spin direction (motor off, by hand) to make sure you're still aligned properly.
If you get things put back together and the prop spins both directions with controls in neutral, but forward, reverse are not quite on with the 'click' of the controls... adjust the cable as described above where the linkage on motor is in the "sweet spot" / middle of neutral, controls are in neutral, and adjust nut on cable to where you can reattach cable without moving the shift linkage at all.
