Okay I almost have things squared away on my motor.
Again, I have a 1998 3.0L merc 4cyl.
I set my idle to 700rpms at home on muffs. I take the boat to the water put it in and it starts up fine. (Motor cold). I get it up to temp and do some runs up and down the lake. No more than 10 minutes. I take the boat back to the docks let it sit for about an hour. Get the family on the boat and she wont start.
This problem happened before and is why I had the rpms set so high before.
To get it to start I have to push in the "throttle only" button and slide the throttle forward a tad and while it starts to catch I have to feather it. Almost like an old style car.
When it finally catch I hear a screaching sound that lasts for about 5 seconds. (This is the first time it has done this it may be the belt. I remember that sound from a belt in my old car.)
The problem is that I can't get it to start and idle on its on. I can get it to start by manipulating the throttle. Once it is started I have to go to throttle up almost immediately and when I do the boat runs fine.
I guess my question is: is there a procedure to get the idle set right in the manual?
Is there a link to the manual on the site still?
My educated guess is that when I set the idle screw to get 700rpms( the one attached to the throttle lever) I am actually choking the motor of air. Is this right or do I have bigger problems?
