I have a 1989 80 HP Mercury outboard. Engine will start with somewhat ease when cold not using the choke push key button. Engine goes into drive and reverse with no noticable problems. When I get out of the no wake zone and give it full throttle it will only go to about 3300 rpms. I can intermitantly push the choke button about 3 seconds apart and engine imediately goes to full throttle rpm and runs fine. If I quit tapping the choke button in like 3 second intervals it will slack back off to around 3300 rpm. It does seem to idle too high and again push the choke button and it idles back down smoothly. I have had these similar problems and I have rebuilt the fuel pump, new spark plugs, wires, fuel filter, sprayed cleaner in the carbs. Everthing I have done it seems to get a little better. It was only the last time out I discovered the miracle of timming the choke button. Do I need to adjust the fuel air mixture? And if so how is the best way to do it on my engine. It has 3 carbs.
Thanks
any help would be appriciated
Thanks
