  #1
Old August 27th, 2008, 07:15 PM
darren mac darren mac is offline
Question evinrude 175 slow out of hole
Hi again,
My 175 evinrude has no holeshot! It cranks and idles fine but I have to baby it when I put it in gear. After slowly coming up on plane the boat takes off and has all the power and speed I can handle. Absolutely no top end problems. If I hook it up to a hose I can easily crank it and when I put it in gear I can rev her up safely with no problem. However when I am in the lake and crank up I can rev fine but when I go into gear I bog down and the engine dies. I asked on this forum about this same problem and was given some advice to clean the carbs which I did. I carefully measured everything and put it back as found. I used a depth mic on the needle valves of the carb bodies and set them back as found. I have not tried cranking yet as I wanted to know the correct placement of these needle valves. My service manual reads close down and back out 5 to 6 turns, doing this puts them about where I found them originally. Is this correct? The carbs were actually new and I am wondering if they were set up properly when the motor was rebuilt this past spring. I have tried a new fuel bulb and new plugs. someone even suggested that I might be trying to take off with the motor tucked too far under ? I was used to fuel injection so maybe I the driver could be the problem. Looking for ideas ...PS this problem was not always there. It ran great this past spring, I have the holeshot problem only in the last 5 or 6 trips on the water and it is intermittent. Thanks, Darren
  #2
Old August 27th, 2008, 09:48 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: evinrude 175 slow out of hole
Check to see if the timer base (starboard side, under the edge of the flywheel, linked to the throttle lever) moves smoothly without sticking when you advance the throttle. Then take the airbox cover off & observe whether the throttle plates are parallel. Also, the timer base should start it's travel before the throttle plates start to open, otherwise the old girl will puke when you give her the juice.
__________________
Chris
  #3
Old August 27th, 2008, 09:58 PM
Thanks High trim, I'll give it a look.
  #4
Old August 30th, 2008, 03:11 PM
blue_streak blue_streak is offline
what year and model#? does the motor bog down as you advance the throttle? if it does, try the choke button and see if that helps. you could try trimming up a little before you take off as well.
describe exactly how it acts as you take off.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1992 Evinrude 200 Xp very slow hole shot basserjim2 Johnson & Evinrude Outboards 5 August 7th, 2008 09:35 PM
90hp Mercury slow out of the hole lifeboatman3 Mercury & Mariner Outboards 9 June 12th, 2006 06:30 AM
slow out the hole dennisrhall Mercury & Mariner Outboards 5 October 16th, 2004 06:46 AM
boat is slow out of the hole??? msando Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 May 27th, 2004 09:06 AM
slow out of the hole dig Yamaha & Suzuki Outboards 2 January 7th, 2004 11:26 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
