Re: quality outboard repair man
Fixing older outboards is a losing proposition for most shops. The price for the repairs is much the same as for a newer outboard. The problem is that it's a much higher percentage of the value of an older outboard.
Look at the 76 OMC 25hp, for example. Those seem to sell for around $6-800 around here. So, you take it in to the shop and the bill ends up being $300. That doesn't take much these day.
For example, if the throttle shaft on the carburetor is loose, the repair is a new carburetor. It's available, brand new, for $190. Add the labor, and there you are. Or, the clutch dog is bad. New clutch dog, plus even just the forward gear: $380.
All too often, the customer bails, or just doesn't ever show up to pick up the outboard, once they find out the bill.
So, smart shops try to discourage making those repairs. They've eaten enough of them already. The most they can do is to sell the repaired outboard the customer didn't pay for.
It's just bad business. That's why owners of older outboards come here to find out how to fix the things themselves. Then...it all makes sense.
