  #1
Old August 26th, 2008, 09:45 PM
xltier xltier is offline
Default 02 50hp 3 cyl. mercury outboard.e-start
i have no spark to any cylinder.my meter tests 170 ac volts at the green stator wires.i tried a module coil on a cylinder and no help.i disconnected the regulator red wires cause they were shorted together.i diconnected the trigger wires aqnd tested those from the black wire to each of the 3 other wires.and got nothing.i am helping my neighbor out cause a marina said a min.$500.oo cause of the burnt red wires.can anyone help us determine if in fact it is the trigger.they are very expensive to second guess.thanks
  #2
Old August 27th, 2008, 06:25 PM
Laddies Laddies is offline
Default Re: 02 50hp 3 cyl. mercury outboard.e-start
Here the specs from CDI
  #3
Old August 27th, 2008, 11:01 PM
thanks,ill check those tomorrow.
  #4
Old September 1st, 2008, 10:44 PM
got back to my delema.i took all the test i could find.the results are i have 180 ac volts on the yellow stator wires during crank.i have .5-.9 ac volts on the 3 trigger wires when i hook to black and each of the colored wires.hard to believe all the trigger circuits are dead.i checked the 4 module wires.ground to block on black wire.no ground to black w/yellow with key on..5-.9 on the trigger wires.180 ac on other wire.rectifier wires melted together.can it be the trigger on all 3??? they r telling me around $300.00.so i wanna make sure.thanks
  #5
Old September 2nd, 2008, 08:54 AM
I doubt that the trigger is your problem, the melted wires and what caused them probably are and I would check that problem carefully to find the source. With the cost of parts if you are in doubt take it to a qualified repair shop
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 50hp mariner 3 Cyl no spark on #2 Cyl bobgra1 Mercury & Mariner Outboards 2 June 6th, 2008 02:20 PM
02 Merc 115 Inline 4 cyl 2+2 fuel problem? emzle Mercury & Mariner Outboards 2 July 24th, 2005 08:00 PM
02 50hp Tracker NGK Spark Plug Question (suppressor or no suppressor) nospark1196 Mercury & Mariner Outboards 2 September 24th, 2003 12:29 PM
Prop selection for '02 50hp Tracker nospark1196 Boat Topics and Questions (not engine topics) 4 August 24th, 2003 07:26 PM
Water in no. 1 cylinder 50hp Merc 4 cyl. woywoyboy Mercury & Mariner Outboards 35 May 1st, 2002 03:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
