I am looking at buying a boat with a Mercury 2001, 150HP Oil injected, carb outboard. When the seller started the engine while it was attached to the water hose, it did not have a pee stream coming out. After about a minute of running, the pee stream came out but was very hot to the touch. Is this normal? He said it was normal. If not normal, what would a estimate be to repair and what could be the problem.
