Re: 90 Johnson Warm up lever
Your timing may not be advancing when you lift the warm up lever. Watch the engine while someone else raises the lever. You should see the timing move a lot while the throttle moves just a little.
Be sure to push the key in while you crank so you get the extra fuel you need when the engine is cold.
I don't know whose picture that was that I marked up, sorry.
