  #1
Old August 25th, 2008, 08:34 PM
jgaryc3 jgaryc3 is offline
Question Mercury 150 Black max steering saga continues....
OK I have a 1978? (per someone else on this board) Mercury 150 Black Max. I took off my old single cable rotary steering system to install a dual cable rack steering system.
I took the old system off no problem.
I ordered a "dual cable connection kit" from iboats for a Mercury Black Max. Upon looking again, it says 1980 Mercury Black Max and newer. The way it mounts is 8 screws in the mount that are supposed to go to 8 pre threaded holes in the motor. My problem is that there are no pre threaded holes in the motor. I am getting so frustraded with this thing I am thinking of just taking it somewhere to have it done. Is there a kit for 1980 and [b]older[b]?
The kit I bought is here : http://www.iboats.com/Dual_Cable_Sin...-view_id.40161
Like I said the holes that are supposed to be there arent. Is this because it was made for 1980 and newer and I have a 78.
Is it possible to connect my motor to dual cable steering? What should I do?
  #2
Old August 26th, 2008, 11:15 AM
Chris1956 Chris1956 is offline
Default Re: Mercury 150 Black max steering saga continues....
It sounds like there is no way to bolt the cable holder to the motor. If that is the problem, you may be able to get a splashwell mount for that cable holder. This mount would bolt to the boat's splashwell and has a ball joint which allows the cable to pivot as is necessary.
Check the Teleflex web site.
  #3
Old August 26th, 2008, 11:55 AM
j_martin j_martin is offline
Check with teleflex, but I bet you could mark the holes with a centering punch (prick punch guided by the hole) drill and tap them.
It's a little more work, but that's the pleasure of running one of the GOOD OLD ones.
Splashwell mount won't work, as the tube has to be close to and parallel to the one in the pivot tube.
hope it helps
John
  #4
Old August 26th, 2008, 01:15 PM
I thought about that. What would I mount it to though? the transom? the motor. there doesnt seem to be a flat place on the front of the motor to mount the mounting bracket to.
Could I mount it to the transom, as far up as it will go, closest in line with the other one?
Should I not use a dual cable system?
  #5
Old August 27th, 2008, 11:32 AM
should I just send it back? the connection kit that is
  #6
Old August 27th, 2008, 01:21 PM
Call Teleflex. They will either tell you how to use this kit, or what the right kit is.
Attached are pictures of a dual cable rig. They weren't intended to be pictures of the steering, but you can see the relationship between the 2 tubes. They have to have a specific spacing so the cross link/steering link adapter.
Do you have a V6 or an inline.?
  #7
Old August 27th, 2008, 01:41 PM
I just put up a query on a go-fast site with many poor folks like you and I on it. If nobody there knows what to do, you may have to fall back to a single rack system.
hope it helps
John
  #8
Old August 27th, 2008, 02:22 PM
On the querie, got 2 replies already. Go look.
http://forums.screamandfly.com/forum...d.php?t=166788
  #9
Old August 27th, 2008, 03:41 PM
the way they do it in the 2nd post looks good. Where could I get those steering link rods though? they look different than mine. Awsome though, I really appreciate it!
  #10
Old August 27th, 2008, 04:01 PM
Quote:
I am not sure? How do I know?
Here is a pic of my engine:
  #11
Old August 27th, 2008, 05:49 PM
That is a V6 motor.
  #12
Old August 27th, 2008, 06:31 PM
That's a V6. The inline is 6 in a row, the tall skinny one.
(The other guy beat me to it because iBoats did it's daily scheduled hang on me.)
The only difference is that the mounting for the older twin tube is by the tilt tube nuts. Shouldn't be too hard to fabricate it.
Spacing between the tubes so the link fits without binding is the only critical measurement. The mounting tabs would have to be quite rigid, though, to prevent the flexing you're working so hard to eliminate.
My next question on the other board is where do I get one. Give it a day.
hope it helps
John
  #13
Old August 27th, 2008, 06:57 PM
Didn't take a day, took about a half hour.
From RK_Outlaw
Have got NOS spacers and nuts, no tube, You can cut and weld two later tubes together to make a longer tube with longer threads on both ends. There are several ways to do this, more than what the info shows.
From gmjim
Hi, i got a complete kit NOS (PN 78834 a2) from a place called sea-way marine, over there in the states! (Seattle i think?) http://www.sea-way.com/index.htm it was only a month or so ago so he may have more?
I dealt with a guy called Paul Shager & i could not recomend him more, great all round service.
The part number from gmjim looks like a mercury part number. Might google it. It may be the wrong number.
RK has the spacers. A little welding and yer good to go, probably pretty cheap. You'd just need to find another junk tube somewhere to add to your's if it isn't long enough. Just tell him I sent ya.
There's some more options for ya.
hope it helps
John
  #14
Old August 27th, 2008, 08:02 PM
John, talked to the guy at sea-way a minute ago. Hes says he has them for my motor. I went ahead and ordered one and will be shipping the other back to iboats tomorrow.
I cant tell you how much I appreciate it!!! Please tell the other guy as well. Paul at sea way remembered the guy from Australia.
Hopefully this will be the one I need. I am curious as to how it will mount though. I guess I will have to wait and see!
Once again, thank you so much for putting your time into it!
  #15
Old August 28th, 2008, 12:20 AM
You'll help someone someday, I'm sure.
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Steering Cable for Mercury 150 Black Max jgaryc3 Mercury & Mariner Outboards 19 August 20th, 2008 12:44 PM
Mercury 150 V6 Black Max badgurl Mercury & Mariner Outboards 4 July 12th, 2007 02:48 PM
Stuck Steering 150 Black Max silv2jo Mercury & Mariner Outboards 7 August 1st, 2002 08:35 AM
1994 Mercury 150 Black Max scp Boat Topics and Questions (not engine topics) 1 May 19th, 2002 08:08 PM
115 Mercury low cylinder - the saga continues alvin Mercury & Mariner Outboards 5 February 27th, 2002 01:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
