fishdog4449
- Jul 16, 2007
- 462
Ok so I dropped the LU last week to rebuild the water pump because the motor wasn't circulating water. well the impeller looked brand new, the vanes hadn't even set yet. Well I put the new one in anyway and put LU back on.
Tried to start it and it would fire and start, but slowly die. Or start to slowly die, then misfire(through prop not carbs) and die completely(see question about this below) . I got it to run for about one minute finally, and it still wasn't pumping much water. There was hardly any coming out of the holes above the cavitation plate, and a bit of a spray coming out the exhaust relief.
There was a very fast stream of water coming out of the lu thru a little hole at the very front.
I don't think any water was getting to the powerhead. I know its possible I aligned the water tubes wrong, but how are you supposed to align them right?
By the time they meet with the pump tubes, the pump is in the way of adjusting them.
On a side note, I removed the t-stat because i thought that could be the problem since the pump was in good condition, so we can eliminate the t-stat for water blockage problems.
My other question is now why does this motor not stay running when it ran perfect a week or two ago. I did remove the carbs and electronics to repaint the powerhead, but I doubled checked the wiring and it's all correct. The carbs were cleaned about week or two ago.
Thanks very much for reading the long post guys!
Very much appreciate it!
Dog
Here are some pics of the motor. If i can get it to start running good again will be going on a friends bay boat.
Dog
