1957 35hp johnson javelin
mikeeo
Hello,
had a motor handed to me , looking to replace the fuel lines throughout the motors interior and wanted to know if anyone has the diameter of the hose I need and where I may find it online?
I had it out and the hose that takes the pressure off the reedcase pinholed.
Also replaced the impellar and was curious if the water on this model engine is dumped out with the exhaust or below the waterline? want to be sure my pump is pushing water.
thanks.
tashasdaddy
Re: 1957 35hp johnson javelin
it is dump with exhaust, but you should get a mist or droplets out the exhaust releif post on the back of the leg. you can get fuel line at auto parts store. just take a piece with you.
