  #1
Old August 25th, 2008, 12:59 PM
Gary de Lima Gary de Lima is offline
Default Yamaha - 1983 2 stroke - 15HP outboard Motor will not start if sitting idle for > 4 h
I am having trouble starting the engine if it sits for over 3 to 4 hrs (typically overnight)
If I squir some gas directly into the Caburator, it starts on the firat crank... and then will continue to start on subsequent tries... except if I let it sit for too long before re-starting.... any suggestions what to look for.
The engine does not have a fuel pump or boost fuel enricher. I believe a membrane in the Carb acts as the pump.
Last edited by Gary de Lima : August 25th, 2008 at 01:07 PM. Reason: changing title
  #2
Old August 25th, 2008, 10:43 PM
triumph190 triumph190 is offline
Default Re: Yamaha - 1983 2 stroke - 15HP outboard Motor will not start if sitting idle for >
If it has a primer bulb you might try replacing it. A common symptom of a primer bulb not working correctly is an engine that is hard to start after sitting for a prolonged time.
There is a check valve inside the primer bulb if it doesn't work correctly gas will leak back into tank.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha/Mariner 15hp outboard motor BDaniels Yamaha & Suzuki Outboards 0 July 23rd, 2008 11:59 AM
1996 15hp 4 stroke Honda outboard raider173rd Non-Repair Outboard Discussions 1 June 11th, 2005 08:33 PM
1996 15hp 4 stroke Honda outboard raider173rd Electrics, Electronics and Trolling Motors 1 June 11th, 2005 08:33 PM
Seized 15HP Yamaha 2 stroke outboard bobcc Yamaha & Suzuki Outboards 5 March 29th, 2005 08:17 AM
2 STROKE 15HP yamaha warrenp Yamaha & Suzuki Outboards 0 September 18th, 2000 07:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
