  #1
Old August 24th, 2008, 03:45 PM
duke.2010 duke.2010 is offline
Default mercury 500 thunderbolt 50 hp timing problem
i have mercury 500 thunderbolt and i have a starting problem and i dont get more that 15 mph out of the engine i think its a timing problem but i dont know how to go about fixing it and i need help with that asap
  #2
Old August 24th, 2008, 03:55 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: mercury 500 thunderbolt 50 hp timing problem
It's usually not a timing issue.
  #3
Old August 28th, 2008, 11:22 PM
so if its not the timeing what is it then ?
  #4
Old August 29th, 2008, 02:41 PM
rafteye rafteye is offline
Weird. I am having the same issue. I believe it to be a fuel issue. It sounds like it's starving for fuel. I'm going to make sure my fuel lines are completely cleared and try a carb cleaning. I'll let you know if anything works!
  #5
Old August 29th, 2008, 05:20 PM
Yepblaze's Avatar
It's usually something like poor compression or a fuel delivery issue.
Sometimes it can be ignition (even timing), but from seeing all the post that come by, I'd guess mostly fuel.
Run a compression check to make sure you have a solid foundation on which to perform repairs.
See, that if by squeezing the primer ball in the gas line while operating the performance immediately improves.
Look to see if gasoline dribbles out of one or more carbs.
Run those diagnostics and get back to us.
Of course, if by chance you, or someone has somehow messed the timing up I guess It could certainly be a timing issue.
  #6
Old September 7th, 2008, 01:18 PM
My issues has been resolved. It was actually a linkage problem inside the control box. There was a burr on the throttle cam that was preventing the throttle from opening all the way. Also found a couple of kinks in the cable itself. Alll works great now! You might take a look in your control box. Good luck!
  #7
Old September 7th, 2008, 05:33 PM
i hope that is the case if not i will add another posting to this form
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Advice on a 1970 Mercury 500 Thunderbolt Ignition 50 HP Outboard oceansoul63 Mercury & Mariner Outboards 9 July 26th, 2009 03:39 AM
Mercury 500 Thunderbolt 50 hp Serialization Mercury & Mariner Outboards 1 April 18th, 2008 09:07 AM
Mercury 500/50 Thunderbolt AGE Colin-R Mercury & Mariner Outboards 2 August 24th, 2003 09:51 PM
1967 500 thunderbolt 50 hp power issue imand344 Mercury & Mariner Outboards 4 July 21st, 2003 08:44 PM
Mercury 500 50 HP Power Problem johnno Mercury & Mariner Outboards 4 July 3rd, 2001 07:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
