Re: johnson motor
bottom cylinder had compression and fire wouldn`t run on bottom cylinder dry plug . 1 carb !. pulled reed plat off the bottom reeds wasen`t closing . the manul said to replace plate and reeds asembley donot attemp to repair . we turned the reed s over they are sealing . will try that . now gitting a gaskett . may have to cut one.
