  #1
Old August 22nd, 2008, 11:12 PM
artee artee is offline
Default minn kota 50#
Need help analyzing a problem. It is 1987 model boat, probably the original trolling motor on this boat. My trolling motor will not run. I hear a click in the motor when I press the foot pedal. The motor will rotate when the pedal is pressed, but the prop will not run.
Where do I start to analyze the problem?
thanks in advance
  #2
Old August 23rd, 2008, 09:49 AM
Silvertip Silvertip is offline
Default Re: minn kota 50#
Clean the connector on the foot pedal cable. If that doesn't help, remove the cover from the motor and feed 12 volts directly to the motor. If it still doesn't run, you have a motor problem. If the motor runs, you very likely have a foot pedal problem. Those pedals did not like being left in the rain and otherwise wet conditions. A new one is about $75 at here on IBOATS.
  #3
Old August 23rd, 2008, 12:29 PM
bhile's Avatar
bhile bhile is offline
This might help too: http://www.konett.com/Minn%20Kota/Mi...r%20Manual.pdf
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #4
Old August 24th, 2008, 12:59 PM
silvertip
Thanks for the advice, I will try it and let you know what I find.
Artee
  #5
Old October 27th, 2008, 09:22 PM
OK guys
Sorry it took so long to reply. I opened the motor and put power direct to the motor, and it ran. I bought a new foot pedal, plugged it in , and still have the same problem. When I push the switch on, i hear a click, but the motor does not run. What else should I check?
thanks
  #6
Old October 27th, 2008, 10:09 PM
Stepping on the foot switch and hearing a click should have told you the foot pedal is ok. Its the relay that's clicking so it is being energized, but the load contacts on that relay are apparently bad. Check the output of the relay and replace it if you don't see 12V when you step on the pedal.
  #7
Old October 28th, 2008, 09:11 PM
OK, I took apart the base of the motor and found the relay and a board with several parts ( a couple of round things and some dohickies, sorry about being so technical). The wires that feed in, has 12v, when I step on the pedal I do not get anything out of the wires that lead to the motor. This probably means the relay or something on this board is bad. Do I have to buy a new assembly, or detemine what part is bad, and can I get through iboats?
  #8
Old October 28th, 2008, 11:56 PM
Whether or not you can replace the individual components depends on your ability to search out off the shelf parts that work the same as those on the board even though they may not look the same. You will not find individual electronic parts of this nature at iBoats. You will likely not get them from Minnkota either as they consider the board the replaceable assembly, not individual components. Relays are fairly common but you need to know the form factor in order to buy a generic replacement. Therein lies the problem. Those parts are not generally marked, and even if they are, they are probably marked with a Minnkota number which only Minnkota can tell you who the vendor was and what the physical and electrical characteristics are.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Minn Kota Endura 50 trolling motor charleso Electrics, Electronics and Trolling Motors 4 June 14th, 2008 06:11 PM
Minn Kota outdrive mounted trolling motor on a 50 hp 4 stroke lou_ky_it Mercury & Mariner Outboards 2 July 25th, 2007 11:49 AM
Minn kota riptide 50 cs/s battery? stevepgill Electrics, Electronics and Trolling Motors 1 August 28th, 2005 10:03 AM
Minn Kota Endura 50 problem TommyWThompson Electrics, Electronics and Trolling Motors 1 August 25th, 2004 08:41 AM
Minn Kota 50 lbs thrust , Ok as a kicker?????? wa3ipb Non-Repair Outboard Discussions 6 August 15th, 2001 04:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
