Re: Chrysler 115 Tilston Carb Help
All the powerheads are good. They are all the same casting with different bores and strokes. All related equipment is the same too. The one weak area was the Magna-Power II ignition which failed regularly. The 115 was never manufactured with Mag-II so there is no worry there. As a 1979 engine, you probably have Prestolite distributor-less electronic ignition. If so, timing is a bit more steady than distributor engines thus a bit less maintenance and a bit more power--not a lot, just a bit. Either ignition system is good and functions well though. My 90 and 140 both have distributors while my Force engines all are non distributor engines. I have no complaints with either.
As a 1979, you may have either the two piece lower unit or the one piece lower. I have been told they changed in 1979 1/2. Both are good but the one piece has several advantages and is engineered a little better.
The two piece lower unit has an 18 (I think) splined prop shaft but the prop is located with a 5/16 pin in the front of the hub. This pin is held in place by the tailcone. I never did like that 5/16 pin taking all the thrust, but I have never had one fail yet. On my two piece, when I use a prop with room in the back, I clamp a stainless split collar on the shaft behind it and let that take the thrust.
Big disadvantage to this lower unit is that if you need a prop, you must hunt for one. As far as I know, no one makes props for this lower any more.
The one piece lower unit has a 15 splined prop shaft, but the prop is located by a thrust washer behind it and inside the hub. The gearcase is much longer than the two piece gearcase and just looks more "elegant." Water pick-up on the one piece is on the side of the gearcase right behind the prop hub. It is lower than the pick-up of the two piece for more positive water flow.
The two piece lower unit is one inch longer than the one piece from engine clamps to cavitation plate. Engines with two piece lower units can usually be run one inch higher on the transom.
