  #1
Old August 21st, 2008, 01:06 PM
inspektorgadget007 inspektorgadget007 is offline
Default Mercury outboard fuel consumption
Ahoy,
Saiboat Challenger 7.4
http://sailquest.com/market/models/chall24.htm
powered by a two stroke Mercury outboard motor, Serial No. 7066273
Question:
-fuel consumption per hour at half RPM, three quarter RPM and full RPM, expressed in litres.
Any idea?
  #2
Old August 21st, 2008, 08:56 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: Mercury outboard fuel consumption
Quote:
Originally Posted by inspektorgadget007 View Post
Ahoy,
Question:
Any idea?
None whatsoever!!!
Let's start with a horsepower....
Rule of thumb for 2 stroke consumption is GpH@WOT=hp/10
Without actually measuring had much is being used nobody can tell you...
Chris.........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old August 21st, 2008, 09:59 PM
Silvertip Silvertip is offline
Put the pencil away, forget the formula, and put a decimal point one position to the left of the last number in the horsepower rating. 40 HP = 4.0 gallons per hour at wide open throttle.
  #4
Old August 21st, 2008, 10:38 PM
achris's Avatar
Quote:
Isn't that what dividing by 10 means????
__________________
  #5
Old August 22nd, 2008, 01:50 AM
Chris and Silvertip,
Thank you for your answers.
Chris, can you translate WOT?
I assume when you both talk about gallon it means American gallon(3.78 l.) not Imperial gallon(4.54 l.)
Is that right?
  #6
Old August 22nd, 2008, 03:49 AM
achris's Avatar
WOT, Wide Open Throttle.... For the purpose of this rough rule of thumb, use 4.
Er, you're new to boats aren't you?
Chris..........
__________________
  #7
Old August 22nd, 2008, 12:31 PM
Hi AChris,
Altough I bought this sailboat in 2005, I don't have much free time to go on the water.
So, more or less stll I'm kind of new to boating.
Again, what gallon is? American or Imperial?
Any rough rule for a diesel engine fuel consumption?
  #8
Old August 22nd, 2008, 12:50 PM
achris's Avatar
Use US gallons.... No rule for diesels, sorry.....
__________________
  #9
Old August 22nd, 2008, 03:12 PM
chrisg chrisg is offline
Cool Re: Mercury outboard fuel consumption
so a 115HP will get 11.5GPH? I assume this is for 2-stroke, 4's are different.
So with a 6gal tank, I can run for 1/2 hour. Mmmm... ther is something wrong with my motor!
__________________
Chris
Gave up on searching for a lake in Iowa!
  #10
Old August 22nd, 2008, 03:17 PM
Achris -- in case the decimal point thing slid past you, it was "tongue in cheek". There are people that go faint when they see a formula regardless how simple it is.
  #11
Old August 22nd, 2008, 09:00 PM
achris's Avatar
Quote:
So with a 6gal tank, I can run for 1/2 hour. ...
At WOT (Wide Open Throttle), yes.... Now if you know how far you travel in 30 minutes at WOT, then you have a mile per gallon figure to start working with for speeds other than WOT...
Chris.............
__________________
  #12
Old August 24th, 2008, 04:16 PM
mthieme's Avatar
mthieme mthieme is offline
My 35 HP Merc burns about 1 gallon per hour at 3/4 throttle.
My 25 HP Merc burns 3 gallons in 1 hour 40 minutes WOT.
But neither is pushing a displacement hull,
__________________
Nothing is so broken that Government can't make it worse.
  #13
Old August 24th, 2008, 06:05 PM
emckelvy emckelvy is offline
Talking Re: Mercury outboard fuel consumption
Actually, the old HP/10 formula was thought up in the days when 2-stroke outboards were rated at the crankshaft.
So, if you use this on a later-model outboard rated at the prop, the value you come up with is gonna be a bit on the low side.
But, HP/10 is sure a lot easier to figure out in your head than HP/8.21 or whatever correction factor you jack into the equation!!!
Here's a good example of this:
Old Merc 1150 rated at crankshaft, approx 11.5 GPH WOT;
Old Merc 1400 rated at crankshaft, approx 14 GPH WOT;
Later-model Merc 115 (which was for all intents and purposes a 140 rated at the prop as 115HP), approx 14 GPH WOT.
And so on, and so on.
Still lots easier for my Pea-Brain to divide HP by 10 and then just jack in a bit more GPH to come up with a S.W.A.G.!!!
And of course the original formula works great on all the Antique Fossil (er I mean "Classic") Mercs we're still playing with!
BTW it shouldn't matter what type of hull you're pushing, if the motor is truly running at WOT, in its rated operating rpm, it's gonna consume the max amount of fuel.
Of course, the type of hull you're pushing will greatly change the Speed and MPG values, as will cruising at the most efficient speed for the hull/motor configuration; but we're not talking about those, only specific consumption at WOT.
Cheers........ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard oil consumption question Neptune1 Mercury & Mariner Outboards 12 June 14th, 2009 11:01 PM
fuel consumption Mercury 402 40HP DutchMerc Mercury & Mariner Outboards 3 June 16th, 2008 08:08 PM
Mercury 50 fuel consumption & Speedo connection mikewallis Non-Repair Outboard Discussions 2 February 12th, 2006 06:58 PM
93 Mercury SportJet 90 Fuel Consumption d.andolsen Mercury & Mariner Outboards 4 July 30th, 2002 06:40 PM
Need to know about outboard fuel consumption Bill Battle Yamaha & Suzuki Outboards 2 January 26th, 2002 09:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
