Re: idle setting ?????
If all cylinders are within 10 percent of one another, which yours are, all is well.
Regarding the idle, set it to 650 to 750 RPM under load and in gear. If you are on muffs in the driveway, set it to 1100 to 1150, then fine tune it on the water.
