Re: Mercury 50hp outboard engine won't pump water
Whoa, read you post again, initially I thought it stopped working after you did the impeller change but now Im not sure what you meant. Was it not working at all before you made the impeller change? If it was not working before double check the port. I have had mud daubers before and other type of restrictions where the pump was working fine but the telltale will not put water out. Good thing is that even if you dont have water coming out of the telltale and the pump is working it will not hurt your motor.
If the telltale port and hose are clean and you are sure your pump and water intake is correctly aligned then obviously there is something wrong. I made an attachment for the mercury so I could run it without the lower unit. I got a clear hose from home depot that fit the water intake and then fit it with a connector so I could get the garden hose to it. I secured the clear hose to the intake and open up the hose. Even with the motor off you should see the water coming out of the telltale. Needless to say, if that works then the problem is in the lower unit, if that dont work then there is a restriction somewhere in the water jacket of the power head. Hopefully it will not get to that. Good luck!
__________________
1975 Cobia Tradewinds SS-170
Close Bow 17 Footer V-Hull
1975 Evinrude 70573-B 70HP
1968 Babcock
Bow Rider 15 Footer Thrihull
1968 Mercury 500 50 HP
Yes, I could google it, but I rather get advise from my Iboats fellow members...
