  #1
Old August 20th, 2008, 11:51 PM
shatter shatter is offline
Default 1971 14' aluminum Starcraft that leaks at them seams.
I've got a 1971 14' aluminum Starcraft fishing boat that leaks mostly at the seams (not the rivets from what I can tell). After extensive google searching I think that I have came across a couple solutions that are within my means. Those being: JB Weld or 3M 5200 Marine Sealant.
JB Weld seems like a good fix, but it's somewhat expensive; comes in relatively small quantities; and seems like it would be sloppy to apply.
Another article that I read suggested that the 3M sealant was a widely used solution, although, I've heard from a post on a different forum that you shouldn't use this sealant like caulking. (http://www.associatedcontent.com/article/326826/how_to_repair_leaks_in_aluminum_boats.html?page=3& cat=11)
The article says:
"One compound that seems widely used is 3M 5200 sealant. The surface of the aluminum and rivet should be cleaned and the sealant is applied much like caulking."
Is any of this article true? or should I stick with JB Weld?
Also, I am aware of people using the spray or paint on truck bed liner stuff. Any testimonies people have using this would also be helpful
Thanks to all who take the time to read and/or respond to this post. Any information would be greatly appreciated.
  #2
Old August 21st, 2008, 01:22 AM
ondarvr ondarvr is offline
Default Re: 1971 14' aluminum Starcraft that leaks at them seams.
I didn't check out the link, but the two products that are designed for that purpose are Gluvit and Coat-It. They're epoxies formulated to coat the entire inside of the hull to seal any and all leaks and work well. Truck bed liner can work, but will cost more to have it applied. I don't like JB Weld for sealing hulls because it's not that flexible and an aluminum hull can take a beating and flex a great deal.
  #3
Old August 21st, 2008, 02:41 AM
Quote:
I was really looking for a solution that wouldn't require lining the entire in/outside of the boat. Would these solutions be effective if I taped off and covered just a couple inch strip along the seams?
  #4
Old August 21st, 2008, 07:34 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Gluvit, is the aluminum boats best friend. do it right or not at all. waste of time and money.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old August 21st, 2008, 11:38 AM
les morgan les morgan is offline
I have a 1985 Bass Tracker tx 17 that always leaked along the keel. After
trying various sealers I finally bit the bullet and had a Line-X bed liner sprayed
down the keel and about 15" on either side of the keel. It stayed on about
11 months and started peeling off. I took it back to Line-X and they said
that the primer had not stuck to the aluminum (looked like bare metal where
the liner came off) they then resprayed for free. That was last October and
it seems to still be holding.. My boat stayes in the water about 90% of the
time, dock is about 15' from my door, and sees almost daily use on the
Currituck Sound of NC.
Les
__________________
oneoarinthewater
  #6
Old August 21st, 2008, 03:17 PM
AZMinyard's Avatar
AZMinyard AZMinyard is offline
A comment with a caveat:
A backwoods, fish-catching, almost always broke buddy of mine recommended using aluminum gutter sealant on the boat seams. This cured about 90% of the leaking in my boat, which was not severe in the first place. One tube sealed all of the seams in my 12’ boat. I did strip down the areas by the seams to bare metal first.
Now the caveat – I just got back from purchasing a $44 quart of Gluvit.
I tried the first method prior to reading through the forum much. I have since come to realize that the remaining leaks are from around the rivets. The Gluvit goes on this weekend, followed by interior paint above and bed lining below. I picked up both the paint and the bed lining at Wal-Mart for less than $6 a can and figure two cans of each should cover the inside of the boat pretty well.
As I said I plan to sand, wash with vinegar, Gluvit, prime, paint and bed line this weekend. If I manage to do so, I will be sure to post pictures and report on the process. I do have a feeling that if the fish aren’t calling that the wife may be, however . . . so we will see if this is a one weekend job or not . . .
Welcome aboard. Two last pieces of advice – listen to “TashasDaddy” whenever he posts, and be sure to search the forums to see what others have done. There are some great lessons under Completed Boat Projects as well.
  #7
Old August 25th, 2008, 12:54 PM
AZMinyard's Avatar
I did manage to get my boat mostly done this weekend:
http://forums.iboats.com/showthread.php?t=273399
The bed liner stuff is pretty good - cooler to the touch than the rest of the boat, definitely a non-slip surface - but a real task to apply. The spray is inconsistent and you will want to tape and cover anything that you don't want to have lined - this stuff goes everywhere!
  #8
Old December 14th, 2008, 02:15 PM
Cornell Cornell is offline
I have a 1972 12' Valco rivited aluminum boat. Best on the market back then. At that age you expect it to leak. It has been car topped on many fishing trips and trailered as well. I took it to the the welding shop where they specialize in aluminum. I prepped the boat with sanding all seams that needed welding so that he only spent 1 hour of welding. To my surprise he put about 5" of water in the boat and put it in the shop to watch for leaks. Then he welded everything. Unfortunately some of his rivits weld still seeped a little water and the seems leaked which he never welded. So I made note of them and marked the leaks (after filling with water like he did) Then I went to the hardware store and bought Instant Gutter Seal in a tube (5oz.) for about $6-$7. I washed the areas needed with lacquer thinner. It is squeezed out in aluminum color and lays in the seams nicely. Used appropriate finger pressure to assure seal. Can't hardly see it as it is the same color as my boat metal. It stays flexable. It has been over a year an Leaks are stopped. And with my 15HP Evinrude it will do 30MPH so the boat is getting tweaked. Slick finish so nothing to slow you down.
I just got the sealer out of my van to get the name and it had been 31 degrees and it was flexable in the tube still. Sticks great to my bare aluminum boat. The Company name is Geocel and can find it at www.geocelusa.com or 800/348-7615
Cornell thecruiseguy
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hole-y 14' Starcraft Aluminum Boat otsegony Boat Restoration and Building 3 July 11th, 2008 01:06 PM
leaky aluminum seams branney Boat Topics and Questions (not engine topics) 8 November 9th, 2007 02:45 PM
14' aluminum Starcraft "V" bottom reload Non-Repair Outboard Discussions 6 July 15th, 2007 10:27 PM
Removing seats in Aluminum 14' Starcraft dave524 Boat Topics and Questions (not engine topics) 5 February 25th, 2007 08:39 PM
70's Aluminum Boat leaking at seams johzak Boat Restoration and Building 8 July 31st, 2006 11:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
