  #1
Old August 20th, 2008, 10:00 PM
Lostuzer's Avatar
Lostuzer Lostuzer is offline
Default 1969 Evinrude 18 HP Fastwin Lower/mid unit water drain ports
18902D - E12329 Converted to Short Shaft
I broke my drive shaft last month and decided while I had the OB in pieces I’d clean, sandblast, and paint. BTW I found this primer and wondered if this is what I should get...
Questions pop up left and right as I delve into this project. One subject pressing me right now concerns the ports I cleaned where the water enters in the lowest places. The ports were sealed shut with what appears to be aluminum oxide and sediment.
I have a question mark on the pics and as best as I can figure the cavity and port meet. I’ve so far removed little the grey/white rock like material from the passageway, from the inside. It will be very slow progression if they do meet.
My questions are:
Is my theory about the “question mark” passageway correct?
Is it necessary that this passageway be opened?
Would it be OK if I drill the ports to approximately twice the diameter to avoid future clogging?
Where can I find some inexpensive paint close to Evinrude blue that will last?
And any input about the primer.
Thanks one and all,
Bob
  #2
Old August 20th, 2008, 11:15 PM
jbjennings's Avatar
jbjennings jbjennings is offline
Default Re: 1969 Evinrude 18 HP Fastwin Lower/mid unit water drain ports
I hope some of the real motor guys check in on your question but I'll try and help a little for now. Most of the holes you've shown are just to drain water out of teh midsection and such so that water doesn't freeze in there and break the housing. You being in Florida, I'm not sure if those holes being perfectly clear are a real problem, since it doesn't freeze hard in Florida as far as I know. I wouldn't drill them twice their size. I'd just clean them out as best you can and don't worry about 'em. I have no experience with that brand of paint. I would recommend that if you use their primer, you'd better use their paint, too. Using different brands of primer and paint is a painting disaster waiting to happen. Make sure you pick a low humidity day to paint the lower unit or it won't stick right. Be sure it's clean and pay special attention to the flash times as well. It's tough to get it to stick to aluminum good enough to stay on.
Good luck,
JBJ
  #3
Old August 21st, 2008, 08:56 AM
F_R F_R is offline
Well, being in Florida I can tell you that those holes are plugged on an awful lot of motors and they keep on going. Given long enough, the corrosion will build up enough in some areas that the pressure breaks the casting. I'd suggest cleaning it out the best you can, but not make them oversize because that may allow exhaust to blow out them and cause cavitation, or in the case of the one under the water pump allow air to enter, affecting the pump prime.
  #4
Old August 21st, 2008, 09:05 PM
Lostuzer's Avatar
Thanks JBJ,
For, “Using different brands of primer and paint is a painting disaster waiting to happen.”
It seems I’d heard that somewhere before but never safely tucked away that tidbit of wisdom.
And thank you F R for good advice and the wisdom behind it.
I finally got the passageway open from question mark to question mark and as I was doing so noticed
in the lower area of the passage on the outside there is a bulge where the pressure had built up.
Who knows how long it had been clogged up in this almost 40 year old motor?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1969 85 hp evinrude lower unit shawshank1111 Johnson & Evinrude Outboards 4 April 22nd, 2008 08:46 AM
1970 Evinrude 18 hp Lower Unit Removal key00pk Johnson & Evinrude Outboards 7 October 14th, 2007 02:22 PM
lower unit drain hole blocked Evinrude 15 hp burnsy111 Johnson & Evinrude Outboards 7 May 26th, 2007 03:11 PM
height of water above vortex plate 1963 evinrude 18 hp fastwin lancsjohn Johnson & Evinrude Outboards 4 July 16th, 2006 12:23 PM
gasket between upper and lower unit on 18 HP Fastwin ksanksan Johnson & Evinrude Outboards 2 July 1st, 2003 08:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
