poppajohn63
- Jul 20, 2008
- 12
I have no spark on any cylinder.
I have the factory manual and it says (pg 111) to disconnect the port Packard connector and see if there's a spark now and there is.
The manual says the problem is in the stop circuit.
It then says to check the black/yellow wire to ground with an ohmmeter. I did and with the key on I get low reistance and with the key off I get high resistance. The is the way it should be but I still get no spark when the Packard coonector is reconnected.
I'm confused - can any body help me?
thanks,
John
thanks,
John
