I have a 69 Chris Craft with a 100 HP Johnson outboard. A previous owner installed a Teleflex steering wheel which I think is too small. Unfortunately I don't have dimensions as the boat is at the shop now.
I seem to be having problems with hard steering at low RPM's. The boat steers better at WOT on plane. I was wondering if it is an issue with the wheel being too small vs. the torque produced at lower idle or if there could be a problem with the internal cable. I am not sure if it is even possible to pull the cable out of the sleeve to lubricate it. It is a mechanical system.
Anybody have any ideas as to what I should check out first?
