  #1
Old August 20th, 2008, 04:08 PM
merczodiak merczodiak is offline
Default 9.9-HP Mercury 2 Stroke hard to start or dies afterwards
Just recently, I purchased used 10' Zodiac along with a two (2) Stroke 9.9 HP Mercury outboard. So, I took both for a trip to my fav. lake for some floating/cruising tests. All went ok for couple of days. The outboard would start with one pull and I was able to enjoy flawless performance, in idle and at low and high speeds. At the end of the second day, I left the outboard tilted out of water, hanging and cooking in 90 degree sun. Later, I noticed little bit of fuel leak from the base of the motor, below the fuel line plug-in. I unplugged the fuel line thinking that it was the cause of the leak. Next day, I came back to continue with my boating fun. But, that's when my problems with the outboard started. Firstly, I had a hard time with start-up. Then, after several pulls it eventually got going. But, after few minutes the outboard would just die. I could not make it idle in neutral or run in gear, at any speed. At this point, I don't know what to think of it or what to look for?
  #2
Old August 20th, 2008, 10:03 PM
jake3340 jake3340 is offline
Default Re: 9.9-HP Mercury 2 Stroke hard to start or dies afterwards
My friend had the same problem with his johnson, try changing the spark plugs to get it to start quick, it could be they are dirty, and for it to keep running check if the carbarator is not clogged, it could be petrol isnt going in the engine.
  #3
Old August 21st, 2008, 05:11 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Fuel leaking with the engine tilted up is normal....
Silly question.... Did you plug the fuel line back in properly? Those ones can appear to be in, but if they are not fully in the valves don't open properly.
What oil and ratio are you using?
What year or serial number?
Chris.......
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
85 Mercury 60 hp hard to start!? insanecreators3 Mercury & Mariner Outboards 5 August 20th, 2008 02:15 PM
Mercury 70 hp hard to start gibby6117 Mercury & Mariner Outboards 1 August 5th, 2007 06:16 PM
1999 9.9 HP 4 Stroke hard to start. Worm Drowner Mercury & Mariner Outboards 0 May 7th, 2007 01:05 PM
Hard to start 2000 150 ELPTO Mercury Two-Stroke gchatel Mercury & Mariner Outboards 1 June 13th, 2004 05:23 AM
1990 Evinrude 70 hp dies - hard to start genedavies Johnson & Evinrude Outboards 12 July 9th, 2002 03:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
