  #1
Old August 20th, 2008, 01:31 AM
Kymasabe Kymasabe is offline
Default Bolt/washer material thru aluminum transom ??
I'll be replacing the transom on my little 12 foot aluminum boat soon, as slowly gathering all the material I'm going to need and was planning on picking up the bolts/nuts/washers this week but thought of a potential problem. Will stainless steel bolts and washers be a problem thru the aluminum and on the outside of the boat. Will the stainless washer react with the aluminum? I will be sealing everything with 5200 or possibly 4200 so that might insulate one metal from the other, though I doubt it. I considered rubber washers but thought they'd eventually compress, causing the bolts to loosen and possibly egg the holes thru the aluminum.
Or...am I worrying unnecessarily and stainless thru aluminum and washered agasint aluminum will be fine?
Is there such a thing as an aluminum washer and should I use one?
Also...exterior...should I use standard size washers or fender washers?
  #2
Old August 20th, 2008, 09:31 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Bolt/washer material thru aluminum transom ??
i use fender then standard on top of the fender.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old August 20th, 2008, 10:03 AM
Tim Frank Tim Frank is offline
I am facing the same thing.
The original bolts on my transom were aluminum, and there is enough separation between stainless and aluminum on the metal activity chart that I think that staying with aluninum is the way to go.
They are available from any good fastener shop. The place I got them had to special order, but they arrived in two days.
They are also available on-line.
I am not familiaer with 5200 or 4200 sealer. What are they?
  #4
Old August 20th, 2008, 10:13 PM
tmcalavy tmcalavy is offline
Marine sealants...available at Wally World and other places.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum Transom Bolt Holes GregE Boat Restoration and Building 2 February 28th, 2008 11:37 PM
What material to bed an aluminum kicker bracket? Trophy24 Boat Restoration and Building 3 March 9th, 2007 08:55 AM
Aluminum boat----flooring material? beneteau Boat Topics and Questions (not engine topics) 3 December 3rd, 2006 11:35 PM
Outboard mounting bolt/washer pulled into transom OceanVU Boat Restoration and Building 6 April 9th, 2006 03:23 AM
pinion gear bolt tab washer capt1992 Mercury & Mariner Outboards 8 March 1st, 2006 04:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
