tomcat8186
- Jul 20, 2008
- 5
I have a 1986 9.9 evinrude. When I test it with the flush muffs I get warm water from the pee hole and the motor does not get too hot to touch even after a few minutes of running. I only get water flow from the pee hole and no flow out of the prop exhaust or from the 6 holes above the cavitation plate. Is this normal? or do I have a blockage. By the way, if I look into those 6 holes above the cavitation plate I see a piece of rubber, any ideas?Thanks.
