Lower unit removal 50 hp. Honda
scovex
I have water in my lower unit oil. How is it getting there? How do I fix it? How long can I run it like it is?
JUSTINTIME
Re: Lower unit removal 50 hp. Honda
better fix it
i usally c it from the drive shaft seals or plugs
hondon
Before you start shotgunning this you will need to determine where the leak is.To do that you will have to pressure and vaccume test the gearcase.The most frequent place for this gearcase to fail is at the driveshaft however you still have the shift shaft,propshaft,bearing carrier,anywhere that you have a mating surface to consider.
