Re: 1994 Yami ProV 150, pulls hard to the right
Assume that you have checked for the obvious? Is the lower skeg straight, no damage or bends? How about the anode skeg? They can be used to adjust off center to correct a pull. Also , depending on your steering cable, most teleflex cables and steering wheels can be centered by removing the steering wheel nut, pull wheel out and reinstall at desired angle. Good luck!
