  #1
Old August 18th, 2008, 09:49 PM
dog5233 dog5233 is offline
Default 1990 Evinrude 48SPL sudden power loss
I am experiencing intermittant powerloss on my 48SPL. Sometimes it runs no problem, at other times, at any speed, it will begin to hiccup severely. Usually if I bring it back down to idle, put it in neutral, and gently rev it, the problem will disappear....for awhile. It may reappear suddenly again in 30 seconds, or may go an hour or two of normal operation at the full range of throttle settings, and then happen again.
Carbs were very dirty and rebuilt by shop this spring to correct low idle problem. Shop advised at that time that engine had strong spark and compression equal on both cylinders and per new specs. They also replaced a defective thermostat. This problem happened once prior to carb rebuild early in the season so I though it was carb related. Engine starts/idles/runs very very well since carb rebuild, except until the hiccup problem recurred.
Plugs and wires replaced this winter. New Moeller gas tank, new fuel (although I know that doesn't mean it can't have water in it). Problem duplicated with two different fuel line/primer bulb assemblies. I do not have a filter water separator, this is on my short list for to-do's.
Any thoughts? I'm wondering about loss of fuel line vacuum at connector fittings, depending on how they are jostled around.
  #2
Old August 19th, 2008, 05:18 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1990 Evinrude 48SPL sudden power loss
vent open on fuel tank?
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old August 19th, 2008, 01:29 PM
Thanks for the response tashasdaddy.
Yeah, tank vent is open. But, you raise a good point. On my two new 6 gal Moeller tanks, the vent in the filler cap is really a flimsy affair. When you close it, it's a fine line between closed and overtight - very easy to tighten it until it agin becomes loose, like you are stripping the threads. Similarly, it's a fine line between open and practically falling off. Maybe I need to make sure it is really open enough. Just cracking the vent on a cool partially filled tank is enough to equalize pressure, but maybe there's still to much restriction for the fuel pump to overcome if it's not open enough. Shooting in the dark here...
  #4
Old August 19th, 2008, 01:58 PM
if the carbs were that gummed up, the fuel lines could have been also, and stuff is not breaking loose, fouling the carbs.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old August 19th, 2008, 03:57 PM
hmmm.
Service records from previous owner indicated no carb mork over last 6 years, I just think they were ignored. Winterization and other items were done religiously.
I have two fuel hose/bulb assemblies. One is aftermarket and new this year, the other is OEM - I'm not sure but it does not appear externally to be very old either. First time this happened was with the new hose, dirty carb. And since has occurred with both hoses at least once or twice.
I have drained both hoses and have used them to siphon from one nearly empty tank to another at the end of the day, have not noticed an debris or particulates of any kind in the fuel.
When I install a separator, should I just have the quick disconnect fittings at the engine and tank like now, and make all other connections permanent with barbed/clamped connections? This would keep the fuel lines and bulb aboard always - currently I remove the tanks and fuel line when not in use and store in a cool shed. Adding more quick disconnects would allow line removal but would also introduce more potential leakage paths I would think.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1971 Evinrude 50 - sudden power loss JT! Johnson & Evinrude Outboards 8 August 14th, 2008 07:24 PM
Sudden Loss of Power wolfpaq91 Johnson & Evinrude Outboards 3 July 2nd, 2008 02:52 PM
6hp sudden power loss mefishalotz Johnson & Evinrude Outboards 8 August 30th, 2007 11:16 PM
1987 Evinrude 60- Sudden loss of power jwebb2ni Johnson & Evinrude Outboards 4 June 13th, 2007 12:32 PM
Sudden power loss - 75HP Evinrude wolgemuthg Johnson & Evinrude Outboards 2 August 8th, 2005 07:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
