Johnson 3hp impeller replacement, JWF-22C
Labdog1
I am replacing the impeller on this folding shaft motor and I have seen on various web sites mention of an O ring on the shaft. When I took off the lower unit there was not an O ring. There is a round rubber seal just inside the lower unit that is surrounded by a round brass piece that is pressed into place and the shaft runs through this rubber seal. Do I need to replace this seal/ring and if so does anyone have a part # to reference? Also, are there any helpful hints for installing the impeller? Thanks
Vic.S
Re: Johnson 3hp impeller replacement, JWF-22C
You will find exploded parts diagrams for 1968 models (JWF23) HERE Theymay well be the same. Worth a look.
