22E6441
- May 29, 2008
- 376
So before I go up to the cottage this year I figured I should change my wheel bearings. I just bought my boat this year so I don't know *for sure* when anything was done to it. What I did know is that my seals were gone....so what the heck...lets change the bearings.
good tip - don't take the tires off the hub - leave them on!!
the first wheel I took the tire off, then took the hub off. It didn't want to come off...really had to bang it and wiggle it off. The spindle looked rusted and slightly pitted too....not so good. Anyway, I cleaned up the spindle and took some sand paper to it to get rid of the rust and smooth it our a bit....pretty pleased with the result. the outer bearing and race fell right out of the hub, but the rear bearing didn't want to come out at all. banged it a bit and out she came.....but the race for the inner bearing was a killer! this is where my handy tip about comes in handy.....hindsight is 20/20 though. I used a large flat head screw driver and a hammer to bang out the race, but it was hard because the hub kept moving and wanting to tip over when I hit the race. finally got it out.
cleaned everything up, banged in the new races....outer was easy...slid in nice. inner was a killer again. oh well, slow and easy wins the race, and after about half an hour of light banging with the driver / hammer the races were seated. Greased the bearings by hand and reinstalled.
I can't believe how quiet the wheel is now.
My other wheel was harder to come off the axle. I had to use my "attitude adjuster" 3 lb hammer to bang it off the axle...and the inner bearing stayed stuck on the axle. I had to smash it all apart before it moved....was worried about damaging the spindle since I had to hit it so many times. I scored it a bit, but smoothed it all out for the most part. Taking the races out was much easier with the tire on the hub still since it was a much more stable platform to work with.
Got it all finished and adjusted.......seems great. can't wait to drive with it and see if I get better mileage and a quieter ride. I was surprised the bearings were as bad as they were....I don't think they were ever maintained.
Next time I do this job I think I could do it about half an hour.
