I have another problem with my outboard. The motor does not lock down when in reverse. My guess is something is out of adjustment, but I'm not sure what it is that needs adjusted to lock the motor down in reverse.
Also the steering seems to stick pretty bad when I turn to the left. I have greased the zerk on the steering without any results. Any suggestions.
Thank you
Kim
Thank you
Kim
