Re: location of water discharge(pee hole)
Does that model have a tell tale? I had a 76 with one but believe it was retrofitted. Cant recall now.
If it does, the water should exit there. If it isnt 'pissing', it is either clogged, the water pump is faulty, there is a blockage in the cooling system, or the water intake area is blocked.
If it does not, the water will exit via the prop and the exhaust relief.
