  #1
Old August 17th, 2008, 08:30 PM
funster funster is offline
Smile 1996 Evinrude 112 sp stalls out under load
Hi Everyone,
My 1996 Evinrude 112 sp stalls out when pulling a wake boarder or skier at about 4000 rpm or so. It acts like it is running out of gas and I thought that either the gas cap was not venting or there may be some obstruction in the gas line or in the tank. The tank is beneath the carpets and not easily accessible. Or, I thought it could be a fuel pump problem. Sometimes when it does this it seems to be running on only two cylinders. The boat always starts shortly after this happens and sometimes when I ski it happens two or three times in a row and then not again. It happens with a full tank of gas or with a near empty tank of gas. It also happens when the boat is under way sometimes when not pulling a skier or wake boarder at about 25 miles per hour.
Other than this problem the boat runs fine. Some times the throttle control can not find the start position and I have to put the throttle lever/shift lever into forward gear and then back to neutral to be able to start the motor. Could this be related? Could throttle position have some effect on the stall out?
Also, when the motor stalls like this the fuel gauge drops temporarily toward empty. I thought it might be an electrical problem like the ignition switch, but the fuel gauges are memory gauges and turning off the ignition switch does not make the fuel gauge needle drop, so I am not sure what is going on.
The other day, after I had the run the boat for several miles, the motor flooded and would not re-start, after sitting for awhile, for some reason. This has never happened before. I notice there is a solenoid that must pump fuel to the carburetors instead of a baffle style choke. I thought maybe this could be malfunctioning and flooding the engine sometimes when under way, but I doubt this is happening.
Finally, I put some gas dryer in the tank thinking that water may have gotten into the tank, but it still stalls out and seems to do it more often each time I use the boat.
Any help would be appreciated.
Thanks,
Mike
  #2
Old August 17th, 2008, 09:18 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1996 Evinrude 112 sp stalls out under load
the red handle on the solenoid should be in this position, (picture) try pumping the hose primer bulb, when it starts to die, see if it picks up.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 112 (SP) Trim Problem No Hook Em Johnson & Evinrude Outboards 5 October 10th, 2003 07:24 PM
HELP!!!!!!Anybody know anything about 1996 Evinrude 112 SPL's kk4560 Johnson & Evinrude Outboards 3 September 19th, 2003 03:19 PM
112 sp evinrude trim mike818 Johnson & Evinrude Outboards 8 March 28th, 2003 03:29 PM
1996 112 evinrude w/ bad piston fluker Johnson & Evinrude Outboards 0 November 22nd, 2002 05:57 PM
evinrude 112 sp firing on only three mylin Johnson & Evinrude Outboards 2 July 3rd, 2002 03:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
