  #1
Old August 17th, 2008, 05:47 PM
bpearce bpearce is offline
Question 2000 Mercury 8 HP Will Not Start
My 2000 Mercury 8HP has very few hours on it. It has not been run much since last winter. I have cleaned the fuel filter and verified gas is going into the carburator; made sure I have fresh fuel; spark plugs look good; unscrewed the nut under the blue primer button and clean fuel came out; it was running for a few minutes last week but now it will not start. Can somebody give me some direction? Thanks
  #2
Old August 18th, 2008, 12:00 AM
Wee Hooker Wee Hooker is offline
Default Re: 2000 Mercury 8 HP Will Not Start
Funny, I have similar issues with a 99' 8hp Mariner right now. Here's what I did to isolate. First, get a (new or well cleaned) spray bottle ( like houshold cleaners come in) and add some fresh 50:1 fuel mix in it. Open the throttle body butterfly by rotating the cam on the left of the carb and spay a few shots right down the thoat. Now give it a pull. If is starts and runs a few seconds, you have a fuel/carb issue. If it starts and stalls, try squeezing the ball on the fuel line to see if forceing it fuel helps. If not, go to an auto parts store and get a inline spark tester for $5. Put it on one cyl, pull the cord and see if you get spark. Then try the next. If you don't see consistant spark on both cyl, you have an electrical issue.
FWIW, mine is a fuel issue and I'm going to clean and rebuild the carb and fuel pump.
hth
  #3
Old August 19th, 2008, 10:16 PM
Thanks Wee Hooker. Do you know how to clean and rebuild the carb?
  #4
Old August 19th, 2008, 11:58 PM
Not well enough to explain here. As a rule of thumb, I take lots of close up digital pics as I tear everything down so I can see how it goes back togeather. I also segrigate parts , bolts etc into (labled) zip lock bags to keep order to reasembly. Then soak everything in carb cleaner for 2 days, then reasemble with new gaskets , needle valve, etc. A shop/repair manual helps allot with pics and float level specs but some of that might be here as well.
It's not hard if you just take your time .
hth
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000,115 Mercury, Hard to start? wibass Mercury & Mariner Outboards 2 August 5th, 2008 01:10 AM
2000 70 Hp stalls hard to start up again ermess Johnson & Evinrude Outboards 7 October 25th, 2005 06:22 PM
Hard to start 2000 150 ELPTO Mercury Two-Stroke gchatel Mercury & Mariner Outboards 1 June 13th, 2004 05:23 AM
2000 25 hp Mercury Tracker won't start Catu80 Mercury & Mariner Outboards 1 May 31st, 2004 07:52 PM
Mercury 9.9 4-stroke 2000 won't start LooseEnds Mercury & Mariner Outboards 1 June 9th, 2003 07:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
