Re: electric problem 40hp 77 mariner
There are a number of different starter switch wiring configurations depending on make and model.
If you didn't get the right switch for your motor, or wire it up exactly right, it is possible to injure expensive electronic components on the motor.
For most of us that can do this sort of work (hopefully without messing up) we use the electrical schematic for the motor, the electrical schematic for the switch, (or draw up our own schematic from inspection and testing) along with a electrical meter to verify contacts and wiring.
Then carefully proceed.
There are way too many variables to take chances.
Get the manual with schematic diagrams, get the diagram or make one for the switch, grab your meter, and go from there.
If you have ruined any electronic components on the motor that would have to be diagnosed on and individual level by the process' put forth in a service manual.
PS if they did not provide you with a switch that will fit your requirements, that would need to be addressed also.
