Ok, so I look at how out drives are geared and to be honest I am confused. (Nothing new in that.) It seems as though everything is set up so the engines max RPMs are in the 4400 to 4800 RPM range. So my question is, what about an engine that can safely run at higher RPMs? As an example say a Chevy LS-1 (350) that has a read line around 6200 RPM and develops lots of ponies above 4500 RPM?
Is there a reason the outdrive manufactures don't want these higher RPMS? It seems a bit strange to me that you would gear it to the point it can't spin that fast and then put a steeper prop on the drive.
Help me out of this confusion...
