  #1
Old August 17th, 2008, 12:02 AM
RMSBuffalo RMSBuffalo is offline
Question Timing marks wayyyy off 200 hp mariner
I'm trying to time this motor but following both the Seloc and Clymer manuals, they say to turn the flywheel to drive the piston .042 off TDC. Then supposedly the timing indicator should line up with the .042 mark on the flywheel. Problem is it's so far off, I can't move the indicator even close to the mark.
The motor's running rough ("chugging"), but there's no carb adjustment for fuel mixture. What I've done so far = Compression check 110 to 117 PSI. New plugs, replaced 1 coil (plug wasn't sparking), Tore down 3 dual carbs and cleaned and replaced gaskets & seals. It seemed that all that was left was to time/syncronize but the marks aren't right. Any suggestions?
  #2
Old August 17th, 2008, 12:05 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: Timing marks wayyyy off 200 hp mariner
Firstly, use the cylmer and seloc manual for toilet paper and get the Merc genuine manual. Secondly the correct depth for the piston for checking the timing mark adjustment is 0.462", not 42 thou... Get the right manual....
Chris............
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old August 17th, 2008, 11:13 AM
My mistake, the manuals did say .462, I didn't have the books with me when I posted and was speaking "off the cuff". Doesn't change the problem though, it's the .462 mark I can't line up with. I agree the manuals suck and they pretty much copy each other almost word for word. So the situation is this:
I'll have to research where to get the Merc manual, and no doubt by the time I get it the fishing season is pretty much going to be over for me. Any solution to the problem I posed?
  #4
Old August 17th, 2008, 09:54 PM
achris's Avatar
What's your engine serial number and I'll post up the right info....
Chris...........
__________________
  #5
Old August 18th, 2008, 03:05 AM
achris's Avatar
sorry, double post
__________________
  #6
Old August 18th, 2008, 12:45 PM
j_martin j_martin is offline
The 16 amp flywheel can be disassembled and then put back out of clock. If that's what's happened, you need to take out the ring of bolts on top of the flywheel, line up the marks, and reinstall it. The splined hub is keyed and only goes on the crank in one position.
hope it helps
John
  #7
Old August 20th, 2008, 07:24 PM
Thanks for getting back to me guys. Sorry it took a while for me to view but I was out of town a couple of days.
The serial # is OB232180 I believe this is around a 1989 model year but I don't know for sure. The serial # doesn't seem to match up to all web sites and doesn't really match out with the manuals although I haven't had any problems getting parts.
The flywheel being off clock...hmmmm....that is what I suspected but I didn't know for sure if it could just be put back on differently. From your post John, I'm reading that the hub is splined but the flywheel can be changed on the hub. If this is the case I can just remove the flywheel without having to mess around with any splines, and just slide it over a bolt or two so that the timing mark is at least in the right neighborhood. Once it's close I can fine tune it and then run the timing light. Sounds good, I'll try it now and keep you posted.
Thanks again,
Jerry
  #8
Old August 20th, 2008, 09:13 PM
achris's Avatar
It's 1987... and here's the procedure for setting up the timing pointer...
__________________
  #9
Old August 21st, 2008, 11:20 AM
Thanks for the info Chris, however those are the exact instructions I've followed using the TP manuals. Problem is the timing mark on the flywheel doesn't even enter the field of the timing pointer adjustment. I did follow the advice of another poster, (J_Martin) and moved the flywheel over by one bolt hole. That took the timing mark to the other side of the timing pointer though, so I still can't calibrate to it. The only things that I can think of are that my dial indicator is lying to me or I reading it wrong (though I can't imagine how), or I'm measuring the wrong cylinder. The books say Cylinder #1 which is top cylinder, starboard side, right?
Interesting observation from your last reply though...
You posted info for Serial#6073192 and above. Does that mean that my Serial #OB232180 is above #6073192? Nothing that I've read anywhere references the letters in the serial # so I've kind of ignored them. If my motor is in fact above 6073192 then I've probably been reading some of the wrong info for my motor which would explain why some instructions don't seem to fit. Unfortunately it doesn't change the timing mark calibration because it looks the same for all of the motors.
Thanks again,
Jerry
  #10
Old August 21st, 2008, 11:36 AM
achris's Avatar
Jerry,
Yes, the lettered serial numbers are later than (above) the 7 digit numbers...
Silly question... you are turning the engine the right way when trying to set to the 0.464" marks?
Just a thought....
__________________
  #11
Old August 21st, 2008, 12:17 PM
Chris,
Wow, you must be on the forum right now!
I've second guessed the rotation a dozen or more times and really can't see that I would be turning it the wrong way, but to verify, when the manuals reference turning it "clockwise", they mean clockwise when looking down at the flywheel right? (They wouldn't be talking about prop rotation would they?)
When I put my dial indicator in the cylinder(I think it's probably a pretty crappy dial indiicator but its the only one I've got), I'm spinning the flywheel and the needle does a few revolutions until it reaches TDC where it maxes out and starts going down. I'm setting that point as zero. Then, I'm backing off from zero until the needle goes aprox 1/4 revolution past .462 wait a minute, I think I just figured it out.
Are the manuals talking about using a specific "Mercury" dial indicator? The dial indicator that I'm using measures in a clockwise direction, meaning in a clockwise direction it goes from 10 to 20 to 30 etc. If the mark of .462 is for Before top dead center, then when turning in a counterclockwise direction from TDC, when my gauge reads .462 it is actually .538 Before TDC which would explain the timing mark not even being in the pointer window. This may be an interpretive problem whereby the manuals are referencing what a specific tool reads as opposed to what the actual measurement is. Does that sound right?
Jerry
  #12
Old August 21st, 2008, 12:46 PM
bjperry bjperry is offline
Jerry,
You may be onto something with your dial indicator. I too use a cheapy from Harbor Freight. I set mine at zero when I get to TDC then back it off to .462. On mine each rotation of the needle represents a travel of .1 inch so I need to make 4.62 complete rotations in the needle before I'm where I need to be.
Incidentally I purchased a used powerhead for my 78 v-6 150 and ran into the same problem with the timing marks that you are. I just assumed it was because whoever sent me the power head used a flywheel that wasn't made for the motor though it would fit. I solved it by using the flywheel off my old powerhead and haven't looked back. Still, since you've tried correcting the problem by adjusting the flywheel I suspect you're problem is actually that you've been misreading your dial indicator. It took me several times the first time I did it to actually make sure I was on the money; not something you want to mess up that's for sure.
Let me know if you have further questions.
Benjamen
  #13
Old August 21st, 2008, 02:10 PM
It's unclear to me what you're doing. Some notes:
1. only rotate the engine clockwise. Going backward can seriously hurt the water pump.
2. .462 is the drop off from top dead center. If your dial indicator doesn't read upward when the shaft is extending, you have to calculate the difference between where you set it, and .462. At .100 per revolution, you would go 4 turns, then down to .038. Most dial indicators have a second needle that indicates the number of turns from relaxed.
Example setup, Zero would be 0 with second needle on 5. .462 then would be the first .038 from contact.
3. Set zero, then turn engine (clockwise, see note 1) most of a revolution till it contacts the depth gauge, the go to your .462 calculated position.
I use a 15 dollar digital caliper. I tie wrap it on an old spark plug frame with a tab welded on it so the depth gauge sticks into the cylinder. I stick it in and inch and rotate the engine one turn to get it to the high point. Then I hit reset, and push it back into the engine. Then I rotate the flywheel till it gets to .462.
hope it helps
John
  #14
Old August 21st, 2008, 02:26 PM
In Pictures.
  #15
Old August 21st, 2008, 02:27 PM
Continued
  #16
Old August 21st, 2008, 03:53 PM
J Martin,
Step 3 of the manual in the post above specifically says rotate the flywheel counterclockwise. My Merc Shop Manual says the exact same thing. If this had the potential of damaging the impeller (which I can see how it might) why would the manuals say this? I'm assuming you get a different result if you continue to rotate the flywheel clockwise. While the difference may be slight, when dealing with the timing issues of these engines I think I'd rather risk damaging an impeller than toasting an engine.
Benjamen
  #17
Old August 21st, 2008, 04:31 PM
The reason your not supposed to turn the flywheel counterclockwise is that the blades on the water pump impeller will deflect backwards. If you use the starter to crank the engine then it will damage those blades as they reverse direction. That's why they have you turn it clockwise manually after the counterclockwise, so it resets the impeller. If the gentle change of direction when turning it manually damages the impeller, it probably wasn't any good anyhow. I also questioned this because the TP manuals contradicted themselves by saying never turn it counterclockwise and then the instructions tell you to. There is however a bit of a disclaimer saying that cranking after couterclockwise would damage it but not if you manually spin clockwise first.
Jerry
PS Wow, nice to see all the responses and help!
  #18
Old August 21st, 2008, 04:58 PM
Quote:
Originally Posted by bjperry View Post
J Martin,
Benjamen
If you follow step 3, the last move made is clockwise to indication. You go past the mark, then clockwise to it.
1. If the engine isn't about to throw a rod, it wouldn't make but a thou or so of difference anyway
2. Either way, you are coming up to .462" before top, so there is no difference at all.
I prefer to not rotate an engine backward for any reason. It can do damage to the water pump. Why risk it.
That's my story, and I'm stickin' to it.
Jerry, did I help you figure out the dial indicator thing?
John
  #19
Old August 21st, 2008, 10:09 PM
John,
Yes you have helped as has everyone who has responded to this thread. As it turns out, here is the apparent problem:
The spark plugs on this motor are countersunk pretty deep and that coupled with the length of my dial indicator is only allowing me to get .370 of travel on my dial indicator.Therefore, trying to find .462 BTDC is pretty much the futile effort that I have been going through.
This became apparent after you and others on this thread pointed out that each full revolution on the dial indicator equals .100. Unfortunately this confirms I'm an idiot because I was actually going to TDC on the dial indicator and backing it off to what is actually measuring .346 as I misunderstood and ignored the revolutions and mistook the .046 to be the .46 the manual was specifying.
However, per the manual instructions, they say to zero out the dial indicator and then back it off to .462. This simply doesn't make sense unless the dial indicator is actually reading distance traveled backwards. ????? My dial indicator does not, and that would suggest the manuals are telling me to turn the flywheel counterclockwise a considerable amount.
Now, if I'm interpretting it correctly, the objective is to actually measure the top of the piston to a point that is .462 from TDC. This seems to be what Chris is doing with the caliper/modified spark plug insert contraption that he's using. If this is the case, then I think I can figure out a way to do it even though my dial indicator doesn't protrude far enough into the cylinder. Unfortunately it's dark out now and I won't be able to fuss much until tomorrow, but does that seem right?
Here's the big question of the TP manuals though...Wouldn't it make everything alot easier if they told you the objectives of each operation as opposed to just giving step by step robotic instructions? It sure would help us to understand when something isn't working.
TTFN,
Jerry
  #20
Old August 21st, 2008, 10:33 PM
achris's Avatar
Quote:
TTFN,
Jerry
For people who actually have the ability to think, yes.... But remember, these manuals are written for the lowest common denominator.. people who can ONLY follow the numbers on the pictures....
Chris........
__________________
  #21
Old August 21st, 2008, 11:48 PM
Perhaps they should write these in crayon.. Just a thought.
Jerry
  #22
Old August 22nd, 2008, 12:04 AM
Jerry,
Your dial indicator should have at least an inch of travel. The trick is to stabilize the dial indicator so that when you set TDC to zero you can make several rotations and TDC always reads zero. If it doesn't then your indicator is moving a little each time and you won't be able to find .462 BTDC even if you tried. Once you do that you can follow step #3 of the manual above. My indicator has two sets of numbers at the increments; those for reading the indicator forward and those for reading it backwards. In other words the 10 is also a 90 and the 80 is also a 20. That way when it's winding backwards away from TDC all you have to count is 4 complete rotations then take your needle to 38 or 62 depending on which numbers you're reading (assuming yours has both sets of numbers). This link helps explain how to read them; mine looks just like the one pictured. Notice the double set of numbers (primary black, secondary red).
If someone showed you you'd wonder why it's not clicking. It's just not easy to explain over the forum.
Benjamen
  #23
Old August 22nd, 2008, 12:41 AM
Um Benjamin...
What link, what picture?????
Jerry
  #24
Old August 22nd, 2008, 11:20 AM
Necessity is the mother of invention........
And poverty, of course, the father.
That's why I figured out how to do it with a 15 dollar menards or wherever digital caliper.
The reason they do it this way is that at .462, which is roughly 45 degrees from TDC, a thousandth of travel is a fraction of a degree. At TDC, a thou is about a degree. It's more accurate.
There's other ways to do it. .150", for instance, is 25 degrees before
TDC. The idle timing setting isn't critical, just approximate. It is changed when you adjust your idle after startup.
I agree, the instructions can be confusing if you don't know the design, and also that many, if not most folks these days don't have the ability or desire to learn the design. They just want paint by number instructions.
The instruction sets that are all pictures drive me up the wall.
The illiterate friendly sign that most irritates me is the one for the library.
hope it helps
John
  #25
Old August 22nd, 2008, 12:20 PM
Sorry Jerry, I forgot to paste the link.
mini-lathe.com/Measurement/Dial_indicators/Dial_indicators.htm
Add "www." to the front and you should be good.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
4.3 liter plastic timing cover no timing marks? Bansheex13 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 14th, 2008 02:55 PM
Trick to seeing timing marks? Mariner 1988 100 HP w2much Mercury & Mariner Outboards 0 May 20th, 2007 05:50 PM
aq125a timing belt/timing marks RandyJ Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 May 8th, 2007 11:24 PM
Nissan 40 hp timing marks calm like a bomb Honda & Tohatsu/Nissan Outboards 3 March 29th, 2005 06:31 AM
1972 85 hp Mercury timing marks copprhead86 Mercury & Mariner Outboards 1 August 3rd, 2003 07:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
