  #1
Old August 16th, 2008, 06:54 PM
insanecreators3 insanecreators3 is offline
Question 85 Mercury 60 hp hard to start!?
I have a 85 Mercury 60 hp motor in a 15 ft skeeter bass boat. I just bought the boat and took it out once. It runs great once going but is very hard to start and then get into gear without dying. Now motor will not even start even with starting fluid. Has bright blue spark and good compression. I replaced the plugs with new NGKs (buhw). The fuel pump is working and the motor is getting fuel. I mixed the fuel 50:1 with 91 octane and quick silver oil. The motor will start every once in a while and run great until I shut it off and it will not start back up. Also I was wondering if I could get away with putting a 120 hp motor on this boat if I cant get this motor lined out. Thank you.
  #2
Old August 16th, 2008, 08:02 PM
TommyA TommyA is offline
Default Re: 85 Mercury 60 hp hard to start!?
First off don't use starting fluid with on 2 strokes. Second that engine should be fine for that size boat but if you wanted to upgrade the max you could put on it should be a 100hp.
From most of what you have provided it would seem that you are experiencing an electrical problem. What is needed is a good deal more informations about the engine, boat and some history behind both.
  #3
Old August 18th, 2008, 08:44 PM
Thank you for the response. I took it to a marine shop today and they dont know what it is yet either we looked at it for almost 4 hours. It has great compression 140-135-138 the fuel pump is working properly and we put it in correct timing. The only thing is sometimes the #2 and 3 cylinders do not have fire. We switched the rectifier and that was not the problem??? The mechanic is going to check the coils in the morning and go from there. Any other suggestions? Thank you.
  #4
Old August 19th, 2008, 08:02 AM
Make sure to check the stator. It has two windings one for high speed operations and one for low speed. Sometimes the low speed will cause problems with idling. A simple check with a ohm meter will let you know if there is a problem.
  #5
Old August 19th, 2008, 09:57 AM
hunpie hunpie is offline
I also have a 150hp Mercury outboard that was very hard to start, the first thing I learned was to press the ignition key until a hear a beep, that help a little with the help of the choke, the second thing someone mention to me was clean the gas tank air vent on the side of the boat (mine was on the side and close to the filler opening), I did with a soft copper wire and white flakes dropped out, now the motor working like a charm. Sometimes the problem is very simpl, so I would like to share my experience with you and others.
  #6
Old August 20th, 2008, 02:15 PM
The mechanic tested the stator and it was bad. Thank you all for your help and suggestions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 60 hp Johnson-hard re-start freetime99 Johnson & Evinrude Outboards 3 August 6th, 2009 11:24 AM
mid-1990's mariner 3 cylinder 60 hp hard cold start kentrx1 Mercury & Mariner Outboards 4 July 17th, 2005 05:58 PM
60 hp hard to start when cold scotgoplen Johnson & Evinrude Outboards 1 March 23rd, 2005 03:47 PM
hard start ups 85 hp force coastal dude Force & Chrysler Outboards 2 August 25th, 2003 03:22 PM
1977 85 hp evinrude hard start when warm HBF4 Johnson & Evinrude Outboards 0 June 16th, 2003 01:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
